A
armereth
Guest
As the topic goes, my car couldn't start or rather stay running. Was fine until 2pm yesterday. When I was leaving my office last nite, I started it but shorly after that I heard a loud "boom" sound coming from exhaust area. Then the engine dies. It can be restarted but just die again. Try another time and this time I floored the accelerator, it revs up to 5000rpm but when released it dies again. This is what I suspect and intend to do. Please advise if there are anything else that I need to look at. 1) Check the connection to MAF - could be culprit because the wire was stretched and the insulator worn.2) Check fuel line for leakage - because I had the injector clean on Sunday. Perhaps some clips are not tighten enough3) Check Fuel pump - need advise how to check?4) Check Air flow - may want to try starting by disconnecting the arms to let air goes straight to throttle body5) Check for fuel overflow - was told but not sure how6) Diagnose with MODIC - Any contacts?FYI, I did engine flush, radiator flush, injector cleaning and gearbox oil change a few days ago. Wonder could these be the cause.My car is now in the office carpark where tow truck cant reach. Are they anyone that do repair on-site?'Thanks in advanceArms
