all you track junkies and track virgins, oct 23rd will be the final open trackday for 2005. it will also be the final any trackday for the year as there are no more open slots for exclusive events til next year. simply put, if u need to scratch ur track itch, oct 23rd is the LAST DAY to do it. Italia Auto will be making a track excursion and it would be fun to have BMWClub along.Date: Sunday, Oct 23rd Time: 2-5pm Venue: Sepang F1 Circuit Fee: RM150 for the 3 hr session Requirements: Helmet & shoes. Gloves recommended. Preparations: 1. Sepang is hard on the brakes. Mandatory to check brake pad thickness and replace brake fluid with a good DOT4 before u go into track. 2. If your car is almost due for an oil change, do it before trackday, not after. u want the best protection when the car is working its hardest. Otherwise, check that all fluid/oil levels are sufficient. 3. Check tire wear and do alignment if required. Check tire pressure just before trackday. U shd run slightly higher pressures (4-5 psi extra) for track. 4. Bring water for ur car and urself. 5. Other than that, come and be prepared to have fun! IA already has about 12-13 ppl signed up, and we're expecting more. I would appreciate it if you could start a signup here so I can gauge how many cars to expect and arrange for pit space accordingly.See you all there!redd
