This is my personal experience from the day :
1. Slalom course
Steering control - my steering work was haphazard. Improved over the day with more practice of the push-pull method which I will try to use daily.
Throttle control - sometimes I am off throttle without realising it. After a few pointers and practice, I managed to maintain a constant RPM (4,000 in 1st gear, 3,000 in 2nd gear) when doing the slaloms.
Car control - going round the cones at constant RPM is not so easy. I think I didn't hit any cones. I keep on turning into left turns too early, which I was informed is a common "symptons" for RHD drivers.
2. Braking course
Brake pedal control - I managed to do one good run - no locks, no screech, no drama, hitting around 80+ kph. The chief instructor actually varies the position of the cones so that you don't "cheat" by looking for braking points on the ground.......basket!
The Kookaburra One actually lost traction on the run up when hitting 2nd gear, coz there is some loose gravel on that section. I may have flatspotted the tyres - the drive back in the Kookaburra was quite bumpy but there was no carbon fibre bits to break off like Kimi's
3. Handbrake turn
I think this was the most difficult course for most people, as none of us are the gung ho road racers who regularly pull handbrakes. I managed 1-2 good turns but the Kookaburra's handbrake is only good for 90 degree turns, the rest of the turn must use throttle to throw the tail out.
4. The autocross
Putting everything we learnt on the day plus more. The loose surface on certain sections means you can't power out at will and must be on your toes at all times. It was a straight forward course but as with most driving course, smoothness is rewarded.
Most didn't manage the handbrake turn, but we will close one eye for this round
Next time there will be penalties involved or there will be a big signboard waiting for those that wants to bypass the handbrake turn box!
