E90 parts & maintenance
consoglieri;824636 said:
Yup,the big round one.where did u get the micro filter?is it a carbon filter or the normal one?
From bavarian auto at SS18. it's for the air cond 1.. located below the wiper.. it's normal 1..
Original bmw plugs at rm45 a piece, total rm rm270
Rear msport sachs absorber and mountings around rm1000
Pollen filter at rm75
All sifus, currently my ride 80k mileage now.. What service should done? Steering fluid, spark plug? Gear box fluid? Million thanks reply.
2007 E90 N46B20
08/09/2008
4L Torco SR-1 5W-30 @ $55/L: $275
07/12/2009
Repair windscreen (star break): $120
13/03/2010
2 pcs Yokohama S-Drive 225/45R17: $900
Alignment: $120
30/04/2010
2 pcs Michelin PS3 225/45R17: $1,040
31/07/2010 (40k km ATF service)
7L ZF LifeGuard 6 transmission fluid @ $55: $385
07/04/2011
Oil filter: $30
4L Castrol SLX Powerflow 0W-30 $195
1L Torco SR-1 5W-30: $55 (to top up the balance of 4.25L)
Total: $280
14/04/2011
Respray front bumper: $300
25/06/2011
Coolant (S1229407454 OE) 1.5L: $32
02/07/2011
Brake fluid (83130443028L): $48.17
Labor: $90+$30
Total with tax: $175.35
01/08/2011
Alternator 1 way bearing: $267
Fan belt tensioner bearing: $106
Labor: $45
Total with tax: $420.70
15/10/2011 (60k km oil service)
Oil filter: $33
4L Castrol Edge 0W-40 $145 (bought from Tesco.. :4:)
Total: $178
14/10/2011 (standing by for next change, estimated in 2 months time, will time it before sensor hancur.. :4:)
TRW brake pads, front and back: $300
http://www.bmwclubmalaysia.com/foru...-to-use-an-E90&p=681082&viewfull=1#post681082
18/10/11
Cover plate / engine back cover: RM38
Coolant: $30
Total: $68
http://www.bmwclubmalaysia.com/forums/showthread.php?16436-Learning-to-use-an-E90&p=681374&viewfull=1#post681374
08/01/12
2 pcs Nexen N8000 225/45R17: $758
4 wheel alignment (4x$7.50) + camber for LR ($60): $90
Total: $848
04/02/2012
Replaced front brake lining/pad with TRW pads.
Pad: Bought on 14/10/11 above
Sensor: Bought front and rear @ $35 x 2 = $70, but only front was used. Rear still not changed.
http://upgr8s.blogspot.com/2012/02/bmw-e90-front-brake-lining-pad-change.html
03/03/2012
Microfilter: $83
http://upgr8s.blogspot.com/2012/03/bmw-e90-diy-microfilter-cabin-filter.html
03/04/2012 (69k km)
Valeo AC Blower (64 11 9 144 201): $600
Regulator (64119222072): $350 (bought for spare, keeping in store now for trouble shooting when necessary)
Labor: $50
01/09/2012 (80k km)
Vanos solenoid o-rings: 4pcs x $3 = $12
Labor: $0 (DIY)
http://www.bmwclubmalaysia.com/foru...-to-use-an-E90&p=767914&viewfull=1#post767914
08/09/2012 (80k km)
2L ZF LifeGuard 6 transmission fluid @ $49: $98
Labor: $0 (DIY) 4L were used, balance came from the stock I bought in 31/7/2010 above.
http://upgr8s.blogspot.com/2012/09/bmw-e90-diy-automatic-transmission.html
22/10/12
4L Castrol Edge 0W-40 $129 (bought from Tesco.. :4:)
Oil-filter element 11 42 7 508 969: $30
Labor: $0 (DIY)
Total: $159
13/01/13
Heat Exchanger Gasket: 11 42 7 508 970 @ $15
Oil filter Housing Profile-gasket: 11 42 7 508 971 @ $23
Labor: $0 (DIY)
Total: $38
http://upgr8s.blogspot.com/2013/01/bmw-e90-diy-oil-filter-housing-gaskets.html
08/06/2013 (91k km, 3rd brake fluid change, every 30k km) @ Wearnes Segambut
Brake fluid (83130443028L): $83.62
Labor: $72+$36
Total with tax: $198.10
Hi fellow UDM owners
jst chged my front brake discs and pads at TopSpeed Shah Alam. initially jst wanna get my alignment and balancing fixed. but had to chg the discs and pads too. no hanky panky it really needs to be chged. anyway, here are the cost breakdown. since i'm a newbie and it was my first visit to tht shop, jst wanna compare their prices. was it a fair deal or not.
front discs (Swag) - RM390ea - RM780
brake pads - RM380
brake pad wire - RM95.00
alignment and balancing - RM74.00
labour charge - RM80.00
adjst camber (all 4) - RM200.00
total - RM1,609.00
thanks bros
Bro biz...
Woooow camber adjustment so mahal lor....rm200...
it is normally included in the wheel alignment...
Ya bros.... rm50 each tyre.
He said "bmw ma...banyak makan wang. Inipun sudah discount"
errr.........not to disappoint u bro but sounds like u got ripped off.......
E90 punya camber nak adjust ape? Sikit aje la because no real camber mount. I do mine at Speedline which is expensive, everything for 150 la. That is considered expensive and he washes the rims.
hmm... ok, thanks for feedback guys. really appreciate it. :top:
jst realised.. u guys only commented on the camber. i assume others are not that far off or quite reasonable then.
thanks again.
my best bet for aligment and balancing job still i let Manjee and his team handle our beloved bimmers.
MPS Auto Sunway. Slightly expensive but worth it.
I visit them every 5,000km.
Changed pair tie rods meyle brand at RM500 plus installation.
Could get cheaper at BA i guess but did it together when changed my springs. Less hassle of going for alignment twice.
M3kid;830895 said:
get from bvmauto.com. They have quite some products....if not email them!
Purchased a few items from them. They even do COD. IMO, some of their products are more expensive than BA.
2007 E90 N46B20
08/09/2008
07/12/2009
13/03/2010
Alignment: $120
30/04/2010
07/04/2011
Oil filter: $30
Total: $280
14/04/2011
25/06/2011
02/07/2011
Labor: $90+$30
01/08/2011
Labor: $45
Oil filter: $33
Total: $178
18/10/11
Coolant: $30
Total: $68
08/01/12
Total: $848
04/02/2012
03/03/2012
Microfilter: $83
03/04/2012 (69k km)
Labor: $50
01/09/2012 (80k km)
Labor: $0 (DIY)
08/09/2012 (80k km)
22/10/12
Labor: $0 (DIY)
Total: $159
13/01/13
Labor: $0 (DIY)
Total: $38
Labor: $72+$36
30/06/13
Valve cover profile gasket (Original): $180
Spark plug tube O-rings: $12
Labor: $0 (DIY)
Total: $192.00
http://upgr8s.blogspot.com/2013/06/bmw-e90-diy-rocker-valve-cover-gasket.html
A lot of steering free play.it makes sound at the slightest bump on the road.in my case,can't even adjust when go for alignment.
