UPDATE
ENGINE:
Diagnose - RM300
Programming for new Control Unit - RM1500
RMFD (Computer Control Unit part no:12147565301-0020) - RM7620
4L Torco SR-1 5W-30 @ $55/L: $275
4L Castrol SLX Powerflow 0W-30 $195
1L Torco SR-1 5W-30: $55 (to top up the balance of 4.25L)
4L Castrol Edge 0W-40 $145 (bought from Tesco.. )
lube - petronas syntium 4l - RM213 and mobil 1l - RM48.
Shell Helix Ultra 5w-40 4.5l RM246.38 Radzor@APD Glenmarie
ShellHelix 5w30 6.5ltr -RM552.50 (must be the most expensive oil@ RM85 per ltr)
Petronas Syntium 3000 (5w30) MYR156/4L (require 5.2L)
Mobil 1 0w-40 4+1L rm321
Oil filter: $30
Oil filter: $33
Oil Filter Element part#11428507683 (Original) MYR90
Oil Filter Element part#11428507683 (Original) MYR81
Oil filter :RM40 Radzor@APD Glenmarie
Oil filter - RM66.27
Oil filter rm42
Bleeder Screw: RM18 Radzor@APD
Eng oil level sensor O-ring: rm32
Eng oil sump gasket: rm82
Oil pan rm385
Coolant (S1229407454 OE) 1.5L: $32
Coolant 1.5L :rm39 (radzor@datford auto)
Coolant: $30
Coolant 1 BT: rm55
Coolant hose upper 1 set: rm325
Coolant hose lower 1 set: rm398
Coolant tank : rm435
Coolant tank cap: rm242
Water pump: rm686
Water Pump gasket: rm40
Radiator: rm1125
Air Filter: RM145 Radzor@APD Glenmarie
Air Filter part#13717797465 (OEM) MYR150
Cover plate / engine back cover: RM38
valvetronic motor Rm1800
Alternator 1 way bearing: $267
Fan belt tensioner bearing: $106
Fan belt tensioner: rm235 (radzor@datford auto)
Tensioner pulley: rm263
Deflection pulley: rm128
Fan belt: rm108
Century battery Din 100L Rm460
Thermostat 1 set: rm105
Thermostat housing 1 set: rm245
Gasket profile change at Obermaier - RM 350
Gasket repair kit with o rings and other seals: RM 505
oil seals - RM 80
Vacuum pump - most expensive RM 1100
Rocker cover - RM 300
Vehicle diagnosis - RM60.00
Spark plug 4pcs rm116
Front bonnet damper: rm115
1 pair bonnet absorber Rm170
TRANSMISSION
7L ZF LifeGuard 6 transmission fluid @ $55: $385
7L ZF :rm455 (radzor@datford auto)
Auto pan with filter: rm350 (radzor@darford auto)
7L ZF lifeguard auto oil rm385
AIRCONDITIONING
Valeo AC Blower (64 11 9 144 201): $600
Regulator (64119222072): $350
Microfilter Carbon: RM155 Radzor@APD
Microfilter: $83
Micro filter part#64319142115 (Original) MYR198.00
AC Cooling coil - 1750.00
AC Cooling coil (thai) - RM1350
Expansion valve - 265.00
Blower Motor with Regulator - 880
Compressor (recond) - RM880
Compressor oil 134A - RM40
Rec drier - RM235
Sponge - RM80
Gas 134A - RM60
Remove dashboard - RM390
UNDERCARRIAGE:
Brake fluid (83130443028L): $48.17
Dot4 Brake Fluid 1L (original) part#83130443026: rm47
Castrol Dot 4 -RM23.59.
Complete absorber works: (Original parts):radzor:APD
Fr absorber: 500x2=rm1000
Fr abs cover 30X2=RM60
Fr abs damper 50x2=rm100
Fr abs mounting 125x2=rm250
Fr abs link rod 2x98=rm196
Rr abs 378X2=rm756
Rr abs damper 2x85=rm170
Rr abs mounting 95x2=rm190
1 pair rear absorber bush Rm210
1 pair rear absorber (boge) Rm720
1 pair absorber front Rm960
1 pair absorber boot Rm110
1 pair absorber damper Rm170
1 pair absorber mounting Rm290
FR brake pad 1 set: rm476
FR brake disc 2 pcs: rm406
FR brake sensor 1 set: rm66
RR brake pad 1 set: rm462
rear brake pad Quoted RM 230
1 pair rear brake pad (textar) Rm275
RR brake disc 2 pcs: rm312
RR brake sensor 1 set: rm58
TRW brake pads, front and back: $300
Rear repair kit, brake pads asbestos-free part#34216774692 (Original) MYR440
Rear brake pad wear sensor part#34356789445 (Original) MYR40
Sensor: Bought front and rear @ $35 x 2 = $70.
1 pair brake sensor Rm70
Brake sensor 70
Wheel Balancing + Alignment MYR110
Align+rotate+balancing=rm45
Alignment and balancing free but the co quoted RM110
rm120 rear camber adjustment and rm60 alignment.
Alignment: $120
Wheel align + rotation - RM80.
4 wheel alignment (4x$7.50) + camber for LR ($60): $90
alignment Rm35+camber Rm40
2 pcs Michelin PS3 225/45R17: $1,040
2 pcs Yokohama S-Drive 225/45R17: $900
2 pcs Nexen N8000 225/45R17: $758
Michelin PS3 - RM650 each
toyo sport T1 255/40r17 Rm720
CABIN
Door lock actuator rear 4pcs: rm400
EXTERIOR
Respray front bumper: $300
07/12/2009
Repair windscreen (star break): $120
FR wiper blade 1 set: rm232
Windshiled cleaner - RM11.31
5500k white colour fog light bulb Rm110
