anaksarawak
Official Member
- Jan 20, 2007
- 4,154
Best value: 1 year old preowned AUDI B8 (Might save you RM80K)
New: E90
New: E90
geoffreylee;235436 said:Best value: 1 year old preowned AUDI B8 (Might save you RM80K)
New: E90
bmFIVE;235281 said:Something that I've posted in a cute car forum:
I did a back to back test of the 3 cars on last Sun, it started with the Passat, followed by the A4 Quattro and ended with the 325i. my brief comment as follows:
VW PASSAT
Exterior
The car looks bigger than the A4 from outside (was told that it's based on the chassis of the coming A5), the front end is distinctive with the "tear-drop' headlights. The rear lights are of LED but I found the design a bit out of tune with the overall design (same feel as the Honda Civic's rear end).
Interior
I don't like the interior at all, the wood trim does not match with the aluminium trim, and it looks plastic (but was told that it's real) Driving position is good (electronic seat adjustment for front passengers), leg room is the most generous amongst the 3 cars. The car feels airy, and can sit 5 pax comfortably.![]()
Driving
The Passat shares the same engine with the A4, a 2.0 TFSI lump (also same as in the Golf GTI), with power up to 200hp and max torque come early at the 1,800 rpm band. The car feels urgent the moment the throttle is floored (as expected in a FI car), but it's let down by the auto box which hesitates in changing gear especially at lower gears. Once the car is on the move, it's smooth and quiet, executive in feel. The presumably longer wheel base makes the car more planted at high speed, and the softer suspension makes it less bumpy compared to the other two car. There's an annoying chime which comes on, together with a message in the central LCD screen, when the car exceed 100km/h > the worst feature of the car or any car for that matter!![]()
AUDI A4 Quattro
Exterior
The car looks the most sporty of the trio, with aggressive front and lower stance. The large grille may not be to everyone's taste but it gives it that menacing look that makes lesser cars move aside when seeing it coming from rear. I generally have not bad comment on the look. The car is due to be replaced with a totally new model in 2009.
Interior
The sporty feel extends to the interior, the driver is surrounded by the cockpit (very much like the early BMWs), which has loads of buttons and LCD readouts. The car feel tighter inside after the Passat, and rear seat is tight for 3 passengers. As in any Audi, the material used is top notch. The design is conservative in mainly black, complimented by some aluminium trim.
The 2.0 Q TFSI is equipped with paddle shifts at the rear of steering wheel for swapping cogs.
Driving
The car drives as it looks:SPORTY. The multi-tronic gear box is way better than the Passat's auto. The shifts are smooth and jerk free, no matter how you floor the throttle, the response is quite instance. It also has the best exhaust note among the 3. With stiffer suspension, it's noticeably more bumpy than the Passat, but it's a small trade off for a more sporty drive IMO. The paddle shift works well too, although can't compare with the DSG shift if the Golf GTI.
BMW 325i
Exterior
The E90 325i gives mix feeling on how it looks exteriorly. It's not a car that makes my heart beats faster the moment I lay my eyes on it. I still don't like the rear end, although the front looks quite aggressive HEAD ON.....yes, only head on, once you move around you see a different view (typical of Bangle's design).
Interior
Bland.......that's was the immediate reaction after sitting in the other two cars. The push button start/stop ignition is cumbersome, it's block by the steering and you have to bend your head to insert the key and then push the button. The car feels more airy than the A4, but the interior panels feel plasticky, and this the MOST expensive car of the trio.
Driving
Ah........this is the strong point of BMW, and it doesn't disappoint. The IL6 engine fires to life when the button is pushed, the engine note is so sweet. I grinned immediately when I took the big curve infront of AB Glenmarie, yes, this's what I am familiar with and LOVE it. The 6 speeds steptronic gearbox is seamless, with the IL6 engine (218 bhp) singing when pushed, and rear wheel drive, it's like heaven!The 325i drives and handles the best among the three, although it's quite bumpy due to the run flat tyres.![]()
CONCLUSION?
The Passat doesn't appeal to me at all, although it's relatively good value at RM228k with it's long list of features. So it's straight fight between the A4 and 325i. The A4 costs RM 265k (Euromobile is offering it at RM245k now, limited unit), the Quattro version is at RM 285k and both come with 4 years warranty, where as the E90 325i is retailed at RM 288k with only 2 years warranty. A4 looks better, feels and drive sporty, cheaper to buy and has double the warranty period (hence cheaper to maintain?), but due to be replaced soon. The 325i has a more understated look, but drives and handles better, and the model will last a few more years but it's more expensive to buy and less well equipped.
Tough choice, so which one will you all choose?![]()
KL2DC;235374 said:Your other 'findings' on the dynamics of the car is also subjective and you certainly have the right to your own opinion.
bmrocket;235558 said:As e46f said..i feel nothing can beat the symphony of that in-line 6pot @ 7k rpm..even my wife say's she likes the sound![]()
E46Fanatic;235607 said:My wife gets scared with the engine scream, but my 2year old son strapped in the baby seat behind loves it! Keeps asking me "Go fast fast!"![]()
I actually like the intake induction roar under full throttle at low rpms. Its a growl which comes up and sounds awesome with the windows down. I remember we heard lovely symphony of the N52 under low and high revs at full throttle as bystanders in Sepang during the BMW Driver Training.. where you can hear tyres screeching and the lovely sound of the bone stock engine screaming and growling away before seeing the car appear from the turn down the main straight...
