anaksarawak;771287 said:
RM170 is very cheap! Are the same for E46 CI? I changed mine for a lot more
Not sure if E39 and E46 share parts. I don't suppose the price would be that different.
ATF oil ZF 5.5liter RM48 per liter RM264
Valve cover gasket double RM 102
Valve cover bush 15 pieces RM 60
Workmanship RM120
Totol RM546
days before
brake disc front 2 for RM500
brake pad front RM365
brake sensor front RM35
Brake disc rear 2 for RM420
brake pad rear RM265
Brake sensor RM35
All ORI
upah RM150
how? reasonable?
Peter,
Prices are all reasonable for original parts. Which workshop did the repair/replacement?
Bigger battery better la, consider upgrade if you have many gadgets inside hehe...I'm also using DIN100in my car, just changed last month.
aiseh...i use din66 onny maaaa.....still ok coz no added additional accessories......
din 100 if you got heated seat,heated windscreen wash nozzle,heated steering wheel ,heated wing mirrors,heated tyres,heated cup holders ,heated this and heated that.........:slug:
Previously I have changed to Boge absobers front and back..But its a bit soft..Good for standard but not for lowered car. I tested my fren's E60. He custom the absobers. Dame good handling. So I bought the old junk standard absobers from half cut shop. Sent for custom made the absobers. I took out my Boge and keep it for spare and now using the custom absobers..For me its dame good handling same as adjustable and the absober can be serviced. How soft or hard you like the shop can do it depending what you want. Warranty 6 months for you to test the absober till you satisfied..
If you all changing the old absober, do not throw away the old one as you can repair it and custom. It will cost you RM1600 for 4 absobers to custom including fixing workmanship and the shop at Sri Kembangan..How good the driving feeling on the absober is very subjective. You may test my car to feel it. To me its quite good but to others, depends on your personal feelings.
Just for sharing....cheers..
which shop in SK bro?
Dear All,
Rear brake disc (bmw ) rm 182
Rear brake pad (textar) rm 105 per pair
Front boge absorber rm 405
Absorber rubber boot rm 15
Absorber damper rm 25
Absorber guide support rm 70
Front upper arm (lemforger) rm 310
Third brake bulb socket (bmw) rm 20
Parts from bavarian auto
4man charge rm280
some power steering related fixes today ...
Power Steering Repair Kit (Top) - RM280
Power Steering Repair Kit (Bottom) - RM50
Oil Filter Gasket - RM30
Power Steering Pressure Hose - RM1200
Power Steering Fluid - RM90
Labour - RM400
Hopefully it will fully resolve my power steering leaking issue ...
Power Steering Fluid leaking :-( from the top of the steering rack ...
So what the workshop did is to take out the power rack and inspect the condition of the power steering and at the same time replace those old seal and "rubber"s .. quite a number of them.
The main issue is with the condition of some inner component (not sure whether i had managed to identify it correctly):
- Pinion Input Shaft
- Power Cyclinder
It shows some wear off sign, so they are worried that it might still leak after those seal replacement but this is the cheapest solution for now .. else i might need to replace it with a reconditioned steering rack which will be much more expensive.
Hope this will help to stop the leak ..
BTW, any of u guys experience the power steering rack leak before?
bmw7833;782022 said:
Wat is the reason u want to replaced them bro?
Charged to bill recently.
Yuasa DIN 88: RM470 (2 and half years ago)
GP DIN 100: RM450
some parts changed...
air duct from microfilter to blower - 300 each
trunk rear plastic panel - 200
rear bearing - 260
bro used or new?i take it the assembly that secures the duct to the microfilter has broken on yrs?
Its new..its the tube/pipe that channels air from microfilter to blower.whole assembly
