keigoayam;721675 said:
for front brake disc: RM650 (ori) & RM270 (brembo)
Changed my front brake discs 5 mths ago with BMW ori - RM560 /pair (exclude labour). Price may have gone up now.
guys, my mech said the atf oil he would be using to replace on my car is redline product.. i didnt ask for the price yet coz i was thinking of ZF oil.. is redline as replacement would be compatible?
Disk Skimming Problem solved
My steering was shaking when breaking..
Yesterday sent for alignment and balancing, after the pomen test drive, he said its the front disk rotor problem.
Then i sent for skimming my disk rotor.
After skimming no steering shaking when speeding and breaking.
its cost me RM 45/disk
Problem solved
:top:
recently replaced my old roof cloth and pillars which is the cloth is not sticking and coming out...
Its cost me RM 430.
Did at a cushion shop in seremban...:proud:
went to munich jalan segambut yesterday and got below items quoted
rubber seal - 3/pc
valve cover gasker - 70/set
windscreen rubber - 120
psf reservoir - 70
ignition coil (bremi) - 120 but 110 if take 6 at once
zf psf - 42/litre
i bought only rubber seals 15 pcs and valve cover gasket to change together my vanos seal. other items planned in near future.
went to bomin yesterday and got several things replaced. price as below.
oil filter bosch - 40
ravenol semi EO 5 litre bottle - 135/bottle
radiator behr hella OEM - 850
thermostat OEM - 180
water pump OEM - 150
water hose OE x2 - 150/pc
expansion tank OEM - 250
labor - 450 (350/vanos + 100/others)
View attachment 23621 View attachment 23622
SKYjack;728735 said:
Bro can post Bomin address. Their price seems reasonable. Are you satisfied with their work. Tq
Bomin Auto Trading Sdn Bhd (opposite Mutiara Complex)
No. 565, 3.5 miles Jalan Ipoh
51200 Kuala Lumpur
Tel: 03-62513613
Lai Kok Fai 013-3669889
His brother (John Lai 012-3059926) operates a Motor Workshop specialise in BMW, just next door. Therefore, parts are taken directly from Bomin thus should result in some savings.
Its cost me RM 430.
Bro mind to share which cushion shop you done in Seremban, maybe we can meet up for small TT cause i am from Seremban too he..he.. Thanks
Hi Kogi...
greetings!
Could you pm me where did you get it done in seremban? maybe the contact details?
51200 Kuala Lumpur
Tel: 03-62513613
Tks for the info bro!
Hi guys, I have changed my right rear light bulbs (3rd brake light n rear light bulbs) after the warning came out. BUT after the change the warning light is still on. How do i fix it, need help please.
bimmerholic;727851 said:
Kogi, are those 540i brake rotors & calipers? They look big enough to be one.
no bro bimmerholic..its just a standard rotors&calipers..mayb in pictures its looks bigger..:smile:
drweko;729882 said:
Hi guys, I have changed my rear light bulb after the warning came out. BUT after the change the warning light is still on. How do i fix it, need help please.
Bro, first of all welcome to the club and congratulations on your first post.
It is possible that another bulb or bulbs is/are dying too, when the voltage reading is marginal, it'll flag out as faulty as well.
Kindly introduce yourself in the newbie section and let us know more about your ride.
Cheers.
seewai
Hi e39er, what is the actual name for "flywheel seal"?
I can not find the part in realOEM. Anyone knows the part number?
U mean flywheel oil seal bro?
