it will takes about a month to fully settle, unless u do about 1000km in 2 weeks and go through a lot of undulation. yumchar can, my house near your office.
My routine service and some parts to replace due to water leaking from the thermostat housing and water pump. Here's the breakdown:
1.Oil filter RM32
2.Engine cleaner RM45
3.Water pump RM215 OEM Germany
4.Thermostat housing RM205 OEM Germany
5.Front brake pads RM385 1set BMW ori
6.Front brake disc RM680 (RM340 each) ori BMW
7.Aircond belt RM68 OEM
8.Brake sensors RM59
9.Oil Ravenol 15W40 RM152 for 8 liters approx
10.Labour for all plus reseting service ind RM265
Total damage RM2106.
All were done at Zender Motor Works BMW Specialist Segambut (just before Berlin along Jalan Segambut).
What do you guys think of the charges and parts prices?
Cheers
Zib
My comments in blue.
1.Oil filter RM32 (OK)
3.Water pump RM215 OEM Germany (OK)
4.Thermostat housing RM205 OEM Germany (OK)
5.Front brake pads RM385 1set BMW ori ( RM335 ori BMW)
6.Front brake disc RM680 (RM340 each) ori BMW ( RM 260 each ori BMW)
7.Aircond belt RM68 OEM (OK)
8.Brake sensors RM59 ( RM 30.00)
9.Oil Ravenol 15W40 RM152 for 8 liters approx (Are you sure this price?)
Cheers
Zib
Just ordered thermostat housing due to leakage..rm155.00. Will fix that tmorow..i dont know what brand,but it certainly is Oem part.
Thanks Herbert. Yes that was Ravenol mineral oil I think.But that was what the receipt says. And then I paid more for the discs..but that's ok.
Just wanted to try and see this workshop as I couldn't find any members went there or comment on that wkshop.
The last comment was someone pointing out to a member a wkshop nearby Segambut and he mentioned Zender.
I guess the discs cost more than usual but at least the job and service was good. He threw me a car wash as well.
Next job is to fix my leaking power steering rack. Naidu quoted me RM600 if just the seals need replacing. Otherwise I am looking at Rm2.2k for a refurbished rack or RM1.2k for a used unit.
cheers
does anyone know where can i find 'cupholder' for my e39...went to chopshop they told it was hard to find...tq
For cupholder I would suggest buy new as old ones are brittle and easily break.
I bought at Sunway Mentari call 0192239616> slightly above RM100
brake pad & disc
guys,
seeking for opinion..i am planning to change the front brake pad & disc. Supplier quoted me:
for front brake disc: RM650 (ori) & RM270 (brembo)
for front brake pad: RM180 (textar)
so does anyone had tried the Brembo disc before? notice that quite a big differ in price so i am worry there will be a huge differ in performance too..
thanks in advance
petrol leaking this morning after pumping fuel to full tank
changed the O-Ring and left fuel floater...RM450 inclusive labour and ori parts
not sure if its expensive or not
symptom is fuel leaking underneath the car near the rear left wheel since d smell came from the rear left.....
can c drops of fuel almost every 2 sec interval and of coz heavy fuel smell
RM270 is ori Brembo kah?
keigoayam;721675 said:
guys,
thanks in advance
i asked my regular spare part guy, the Brembo OEM disc is RM270 per piece...its genuine
Bro.. I suggest that you call Brembo Malaysia/authorised distributor (google for contacts).. OEM could be misused in the market to denote replica. May not do justice to your RM
