Why you need part no? Just ask for flywheel oil seal lor. Come to think of it I changed my ex E39 flywheel oil seal at least 4 to 5 times prevouisly till complete changed the gear oil pump. Darn
As i plan to buy the seal oversea together with my other parts, but i can not find the part.
I found the oil stain is getting bigger and i assume now is the right time to get the seal replace.
Yupe bro, i am thinking where should i send the car to get the seal replace too..headache.
why so many times change?
initialM;730330 said:
perfection. diff to explain in 1 post. refer to my thread in showroom section
ok will dig out info from your thread. but at what page to be exact? too many pages. LoL
Bro you will enjoy every single page...from this taiko showroom posting.
aha actually i did browse through all pages before i got my e39. yet every pages never turn me down and that what kept me motivated to go through all of them.
New DIN 88 Century Marathoner = RM410
Sold old battery for RM28 (GP DIN 66, only lasted me one year one month, went dead just after warranty expires ... very nice)
Total cost of new battery = RM382
drweko;729882 said:
Hi guys, I have changed my right rear light bulbs (3rd brake light n rear light bulbs) after the warning came out. BUT after the change the warning light is still on. How do i fix it, need help please.
i also have the same experience. You have to get the bulbs which consume the proper amount of current.
Where did you get the bulb? 2 main ways like some pointed out... either you got the bulb from a normal hardware shop/car stokis which gave you a bulb that looked the same with the same 'kaki'.... but actually is not for the car OR your other bulbs are on it's way out too.
If you got the bulb not from someone who deal with Bimmer things, I would think that particular bulb might be the problem. Happened to my mate... paid and extra $1 for the correct bulb and error went away. Just borrow a mates bulb and try la, if error go away, then u know the culprit de.. Hope this helps
Apparently. alternator is the culprit for my battery problem.
Got it changed yesterday after the battery light came out. It was repaired last year. Quite surprised to see that it lasted for more than a year.
New alternator: RM1480
Labour : RM120
Total: RM1600
Labour : RM120
Total: RM1600
Very expensive. Bro Zidee just changed his alternator about 3 weeks ago, RM810 parts only from BA. Labour RM50. Bosch alternator.
My Battery died-ed on me this morning...
Replaced with DIN 88 Century Marathoner - RM350 after traded in the old one.
You almost gave me a heart attack there. My first thought was that I got ripped off by my own friend there... A quick call to BA revealed that there are actually two types of alternators. One with RM 810 price tag and the other is RM1430. I guess mine is the latter
What are the differences? Anyway just checked with bro Zidee, the labour was RM130 not RM50.
The one he got came in a Bosch box but with BMW logo on the alternator itself. I paid RM1150 for the same one in Penang.
just changed several things.. this is as far as i remember as my dad holds the receipt.
thought the main culprit for the ting-ting sound is my center support bearing or long shaft coupling, but actually its the Constant-velocity joint..to replace they told me around 1.6k
JFT63;718006 said:
Changed my sensors recently..
Camshaft sensor (siemen) rm300
Crankshaft position sensor (vdo) rm230
Why do you change the two sensors....any problems before that?
Sometimes my engine didnt start up. It cranked but occasionally failed to run.. I sent it to w.shop, it was diagnosed and found the culprits. Both were bought from Bomin auto.
At WP,changing..
-flywheel oil seal
-valve cover gasket double
-valve cover bush
-driveshaft oil seal
-oil sum gasket
-long shaft oil seal rear exce
-change vanos seal
Total Rm 1618.00
