Did a scan 1.4.0 on my E39, noticed that the O2 sensors error could be cleared. However once I closed and relaunched bmw 1.4.0 and did a scan again, the O2 sensors error appears again, something like below:
DME -> D9/78 - Signal, CAN EGS, timeout elapsed
4F/74 - Oxygen sensor heater after catalyst, bank 1, open circuit
3D/74 - Oxygen sensor heater after catalyst, bank 2, open circuit
E4/B1 - Oxygen sensor controller, bank 2, deviation too great, deviation rich
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
85/08 - Signal, CAN ASC 3, timeout elapsed
Errors after clear:
Shadow-memory:
So far I could still live with her fuel consumption, mixed driving with medium-heavy foot most of the time, averaging 12.3L / 100km. Should I spend more than 1k to fix the O2 sensors?
This is my dilemma too even my o2 sensors do not create any error code yet.
The errors only appear in BMW Scanner, if press the diagnosis button on meter cluster, no error.
Not sure if the figures below, at idle, could tell whether it's alright not to fix anything at the moment.
# DME LIVE DATA - GROUP 2 (18:22 12-Oct-11) :
Battery voltage [ V ] : 13.7 Engine speed [ rpm ] : 752
Terminal 15 voltage [ V ] : 13.9 Air mass [ kg/h ] : 15.5
Vechicle speed [ km/h ] : 0 Injection duration [ ms ] : 2.7
Engine coolant temperature [ C ] : 84.0 Spark advance angle [ Deg ] : 4.5
Engine oil temperature [ C ] : 74.6
Intake air temperature [ C ] : 48.8 Pedal angle [ Deg ] 0.0
Pedal sensor 1 voltage [ V ] : 0.70
Pedal sensor 2 voltage [ V ] : 0.36
Throttle angle [ Deg ] : 0.1
Engine throttle, signal 1 [ V ] : 0.49
Engine throttle, signal 2 [ V ] : 4.54
Idle speed integrator [ % ] : 94.2
Idle speed control valve [ % ] : 40.7
Inlet VANOS, actual position [ Deg ] : 112.5
Exhaust VANOS, actual position [ Deg ] : -105.4
Knock sensor, cyl.2, mean value [ V ] : 0.20
Knock sensor, cyl.5, mean value [ V ] : 0.24
Load signal [ mg/stroke ] : 114.54
O2-sensor controller, bank 1 [ % ] : 1.12
O2-sensor controller, bank 2 [ % ] : -1.17
O2-sensor heater bank 1 bef. cat. [ % ] : 99
O2-sensor heater bank 2 bef. cat. [ % ] : 99
O2-sensor heater bank 1 aft. cat. [ % ] : 99
O2-sensor heater bank 2 aft. cat. [ % ] : 99
Bro the o2 sensor is RM350 each for pre-cat, post cat is about RM390ish , only need to change the 2 pre-cat ones, length of wire is 570mm for our E39.
The o2 sensor is degraded but still usable, BMW scanner will pick up the error but something as advanced as Autologic wont.
Have all this replaced at WP auto
Double Vanos Seal (groupbuy)
Valve Cover Gasket Double - 102
Valve Cover Bush ($4X15) - 60
Vanos Hose - 102
Presure Valve - 220
Air Hose ($134X2) - 268
Oil Filter Housing Gasket - 38
Liptis Hose Seal - 15
Steering Hose Big - 90
Steering Hose Small - 78
Steering Oil Tank - 68
ATF Oil ZF ($48X7) - 336
Auto Filter 5HP 19 - 68
Auto Gasket 5HP 19 - 55
Front Brake Pad (Ori) - 360
Rear Brake Pad (Ori) - 272
Brake Sensor ($35X 2) - 70
Castrol Magnatec ($108X2) - 216
Oil Filter - 45
Temp Sensor - 75
Steering Oil - 30
Brake Oil - 45
Fan Belt Ori (AB) - 168
Air Cond Belt Ori - 145
ABS Sensor - 248
Plug BOSH ($30X6) - 180
ABS ECU/Module (used) - 1400
**workmanship - 450
Vanos Hose - 102
Presure Valve - 220
Oil Filter - 45
Temp Sensor - 75
Steering Oil - 30
Brake Oil - 45
ABS Sensor - 248
**workmanship - 450
wah... so many parts changes at one time.
vixxx;685058 said:
cryin payin the bil bro, hv no choice
That is what we termed it as Preventive Maintenence. Itu pun not including the under carriage wear & tear parts like tie-rods, lower & upper arms, stabilizer bars, etc etc.
sewell;685118 said:
ya, hebert alawys racun-ing people toward the Eibach anti-roll-bars. wait i kena lottery then i sure buy
Good thing must share with members here. For me, stability of the car give me the confidence to push the car to its limit in times of need. Braking system, tires, suspension system (including ARB) are some of critical parts that I would not compromise.
Not need to wait for lottery strike...just put aside few hundred $$ a month will do.
Car in superb condition already and can lari fast2 right vixx..??? :)
Vanos Hose - 102
Presure Valve - 220
Oil Filter - 45
Temp Sensor - 75
Steering Oil - 30
Brake Oil - 45
ABS Sensor - 248
**workmanship - 450
went to Optimum, following a recommendation from fellow forummer since my regular workshop is so busy that they can't allocate a time for me since a month ago! what started with just the engine mountings ended up with a list so long that my holiday plan for end of the year is thrown out of the window :(
the parts changed :
1) engine mounting = 2xrm235
2) radiator top hose = rm153
3) front wheel bearing = 2xrm380
4) rear wheel bearing = 2xrm210
5) front upper arm bush = rm380
6) rear brake disc and pad = 2xrm380
7) wiper nozzle and hose set
8) front seat cover set
may be a bit stiff but workmanship looks good and most important thing, there are no more vibrations and a quieter ride now :D
Mick,
I am sure your ride now is more comfortable and pleasant to drive as compared to previous. Next item on your MUST DO LIST is application for Official membership.
My bill for the day...
Repairing the starter,@replacing the gear ( i dont know the exact name of the part) rm 160 with labour...
Now I'm relieved without having to spend more RM for the replacement unit.
herbert;685604 said:
Mick,
oh yes sir. ride is now more comfortable and solid. all those noise from the vibration is gone and at times, i couldn't feel the engine running :D
and yes that is next on my must do list ;)
Mick,
Straight to the point!
the parts changed :
Obermaier is ok except that the lady cashier or receptionist.. sometimes she could look so stressed that it made you feel unwelcomed and sometimes she could be so moody that you feel that you are gonna get cheated or there goes my money...ouch!
Until they can find someone to replace her Obermaier will be the last place I would go..
http://www.bmwclubmalaysia.com/forums/images/icons/icon8.gif
