Why need to solder? is there any preventive maintenance needed? this "super E39" though nice to drive sure have enough problems to deal with ah!
That float wire moves up and down up and down continuously, eventually it will break. Just needed to reconnect the wires again, or change to a softer wire since the original one will be very brittle by now.
This car needs love!
No worries bro.
yes I agree. So those who have never changed maybe you need to check those wires. Mine was brittle hence they broke.
But soldering looked risky as a spark could ignite and kabooom!
I have collected my CBU UK e39 530i black premium sport and went for the following parts :
1st Stop - M1 Segambut
Replaced 2 front absorbers and mounting accessories for RM 1860
Replaced missing white side signal indicator - whole set for RM 105
Conclusion, fast and attentive but price is very high - cut throat aka cut neck
2nd Stop - BM World, Bandar Tun Razak
Left side mirror cover dislocated by someone (culprit or passerbys placed the cover loosely back on to the exposed metal mirror, thankfully)
Black glue on 4 legs and taped for for glue setting overnight - FOC ! said is a goodwill service, pleasantly surprised me.
Conclusion, nice and pleasant chats with the young man there, gained insight on the extremes of SC and other good infos. Amazing knowhow.
3rd Stop - HKL Motor works, Taman Segar Perdana, Cheras ( nearby my house )
Lemforder Front Lower Arm 2 pcs x 400 = RM 800
Bilstein Long Shaft Coupling 1pcs = RM 185
Engine mounting 2 pcs x 170 = RM 340
Gearbox mounting 2 pcs x 65 = RM 135
DOT4 all brakes oil flushing/siphon = Rm 32
Intake air filter = RM 48
The checks were performed on my request that the driving wasnt smooth over bumps as i feel the car felt slided sideways. Any other items which the mechanic (boss) suggested to change and hence the above items were ordered and replaced. I have also indicated to him another problem, my steptronic gearshifts from D to S without problems but will be stuck from S to D. Only after a few more tries, the gear will engage D.
showparts.do
This is odd and i fear the worst (few days ago went to another BMW specialst in Kuchai Lama and the boss says it could be this and that blah blah, may need some chop shop items or costly replacements) The boss Ah leong dismantled the gearshift cover from the driver seat and flipping the gears trying to find the fault. He tried it for 10minutes and modified a metal sheet as a retainer to make the shift back from S to D. He did it in 15 minutes. Later i found from the above picture it is a missing item 2 and 3. It was not there in the gearshift assembly. Ah leong solved it without even knowing the missing items and no parts diagrams to refer and i am impressed.
All works completed and after a 2 test drives and checks/adjustments at exhaust portion, the car still have a faint rattling noise. Again the test drive and found the culprit in the rotor back cover having steel debris causing the sound. Another test drive and car up on jacks again for bolts tightening. The determination to solve the noise issue are evidently demonstrated here.
The bill for all the above works are RM 120, i was like OMG. Felt guilty for the bill amount and promptly paid before he change his mind, lol.
Total Bill = RM 1865
showparts.do
This is the price for what I paid at BOMIN:
Lower arm Lemforder RM380x2 = RM760
P/Steering hose RM125
P/Steering return hose RM175
P/steering filter and tank combi RM85 (OEM?)
Rad Hose clamp RM24
Top Rad Hose RM185
Bottom Rad Hose RM165
Rad expansion tank RM280
Long shaft rubber bush RM165
Engine mounting RM330 (for 2 big ones)
Gbox mounting RM119 (for 2 small ones)
Labour RM380
After 3 months driving my E39 523I decided to sent the car in to fix niggling problems and here is the damage :
Brake shimmering (upper arm bush peviously replaced) :
- Brake Disk - Front x2 (BMW) RM560
Transmission Leak :
- AT Fluid 7L (ZF) RM315
- AT Filter & Sump Gasket RM68
Occasional High Temperature (on cold days, ie evening after rain
wutty;675722 said:
Steering rack oil leak (overhaul)
- Steering Rack Repair Kit (ZF) RM280
- Steering Fluid Tank, Filter & 2xhoses (ZF) RM193
- Steering Rubber Boot x2 RM40
- Steering Fluid x2 RM50
- Clips RM8
Is this working to stop the leak?
So far so good but probably take a few more weeks of usage before can safely say the overhaul is successful or not.
BTW the repair kit consists of o-rings and there were many of them. Hopefully all were done correctly.
zib;675784 said:
So you can always stop the fan with your bare hands (provided u wear safely gloves to save your fingers :) )
I wasn't brave enough to do it. It was the mechanic who demonstrated to me how bad the fan was. Prior to that he had tried it with gloves on.
JUST FYI only bukan nak tunjuk pandai. Sharing is caring hehehehee..
Thanks bro. Always appreciate people who are willing to share their ilmu.
I came from a poor family where my family used to have a KE30 (that's a late 70s Corrolla) in the 90s where most families normally have a Proton Saga or even a Wira... So I learnt a lot about old car systems..
Same lah bro. Those days maintenance mostly DIY - oil, brakes , spark plug and even timing pun DIY.
My ABS and ASC light up intermittently since last week with symptoms of late gear change ..got it diagnosed and found the faulty rear right wheel sensor. It was brittle, damaged and broken. He tried to solder the wires for temporary solution but it didnt work...ended up ordering ori sensor and i was quoted rm 380...will fix that tomorrow
Bring the kaput sensor back and ask the electronic guy solder for u, u save your rm380 in future.
I never thought of that bro hehe...but he did solder it back and deleted the fault codes..started the engine again, drove it for a while but the warning still persists..will definitely do it bro..thanks
To clear up my mind, i did replace the original rear right wheel speed ABS sensor rm 350, window lifter driver's side OEM rm 350,...hope there is no more sign of breaking my wallet again in the mean time
