deep3102;575333 said:
Bro,
Whats the purpose of this arr? Whats the symptoms of kaput'ness coming in?
A healthy gas pressurized spring acts fast to pop the boot up with little force.
deep3102;575342 said:
how to know if its healthy or not bro?
1. Ask the doctor or ask the spring itself.
2. Feel it..
3. Compare yours with other car.
4. Check whether get stain along the rod..may be.
today's bill...
1. eng oil castrol magnatec 6.5l rm220
2. oil filter rm35
3. propeler shaft joint rm180
4. inside mdguard cover rm90
5. drain nut rm3
6. labour rm105
total spent rm635.00
23/10/2010
1. Aux electric fan (original) - RM 1,450.00
2. Labor - RM 90.00
Total: RM 1,540.00
25.10.2010
1. 2 pcs Original Rear lower arm ball joint @ RM 97.00 = RM 194.00
2. 2 pcs Original Rear integral link @ RM 93.00 = RM 188.00
3. 2 pcs Original Rear guiding link @ RM 235.00 = RM 470.00
4. 2 pcs Original Rear wishbone arm @ RM 300.00 = RM 600.00
5. Labor charges RM 250.00
Total: RM 1,700.00
25.10.2010.
1. Alignment front & rear & adjust rear both side camber - RM 141.75
deep3102;575335 said:
no la paii, this was just after that drive ni.. on the average, i drive slow slow ni..like the guys put it, "deep reads newspaper and drives his car"..
This i can vouch! And not just any newspaper but the Nan Yang Siang Pau Paper :D
p/s: remember the MEX drive we did that night :p ha ha
herbert;576135 said:
..........25.10.2010
5. Labor charges RM 250.00.........
wah so many parts to it. all i knew was rear lower and upper arms. my mech said he changed all that there is and cost me close to rm2k for the change.
Today's bill...
1. 2 pieces of front Stabilizer link @rm105 per piece rm210.00
2. Mudguard inside cover ( left side only) rm 90.00
3. Labour rm 30.00
Total spent rm330.00
Just found out that my right lower arm is a bit worn out...rm420 per piece....will fix that next month pulak...:smokin:
Miss my car as she will stay over night in workshop today. Wish i can get fresh new feel from her tomolo.
JFT63;577992 said:
Today's bill...
3. Labour rm 30.00
JFT, where did you get the mudguard inside cover for rm90? mine is looking a bit worn, will probably do a DIY.
The shop Bimmerworks BP ordered the item from KL,,just changed both sides..look hensem now..hehe..will ask the mech n let u know the soonest possible.
What's wrong with your car? You haven't done your overhaul yet?
Just collect the car.
Nothing big deal but mechanic ask for one day to replace the vanos seal. Spend RM2200 in overall bill included the regular service, tie rod, arm bush, steering oil tank, oil separator, few hoses and some wear and tear gaskets.
Labor is definitely cheap.
My first service:
1. Oil filter - RM38.60
2. Air cond belt - RM56.00
3. Valve cover gasket set - RM178.00
4. Valve cover rubber seal RM8.20 @ 15pcs = RM123.00
5. Bleeder nut - RM10.00 @ 2pcs = RM20.00
6. Radiator cap - RM82.00
7. Ravenol 10W-60 - 7liters = RM371.00
Service charge:
1. Oil service - RM45.00
2. Renew vanos seal & do timing adjustment - RM250.00
Total - RM1,163.60
Service tax RM14.75
Grand total = RM1,178.35
Bmw e39 e53 dvd
feisaldzul;30380 said:
didnt see any topic on this...lets start one going so that those who are interested will know wat kinda cost is involved in maintainin an e39
e39 owners...pls do post the cost of yr parts and maintenance
cheers
BMW E39 E53 DVD
Best Regards!
hi replay, my mech said he ordered from AB..rm90 per piece..
paultantk;579909 said:
zun: why did you choose to use 10w60?
Because Jason of Optimum recommended me to use that grade. Herbert also use 10w-60. Saya budak baru belajar, so just follow them la.. :listen: Is there any issue with that oil grade? I'd love to know and learn.
Dear All Advisors, just to share the good news that after the rework of the torque convertor, my long standing problem was solved....after so much $$$ earlier trias n errors...Anyway, tks a lot for those offered advices..
What's the damage $$$ like? What work was carried out on the t.converter?
