keigoayam;547782 said:
hi guys,
Just change few parts for my car:
Tie rod (LH and RH from TRW) =rm230
Power strg hose (tank to cooler) =rm85
Oring + hose clip =rm13
Labour for both parts= rm93
Next action is to check the wiring for A/C fan. The fan not running when i turn on the AC.
The root causes i guess is either the wiring itself or the condenser fan motor.
Have anyone experience this? TQ
Better get that Electric Aux Fan replaced before it overheats your engine. More often than not, it's a burnt fuse or the motor itself kaput.
Wondering if anyone here has used a full set of Bosch brake discs and pads. Any comments?
These are the price for a BMW 530i in the UK, I can get full set discs and pads for front for GBP90 (RM452) and rear GBP102.95 (RM517) . Total RM969 for a Bosch brand - that didnt include the sensors.
Also I just got a quote from a BMW dealership, GBP300 (RM1500) all in, rear and front discs, pads and sensors all original BMW. Good price?
Which one would you go for? How much are these things in Malaysia? Should I buy a set here or just change it in Malaysia?
deep3102;466577 said:
here's a list of things i replaced for my E39 528i:
Items RM
Front Brake Pad 365
Disc Rotors 320x2 640
Brake Wear Sensor 48
Rear Brake Pad 285
Brake Disc Rotor 305x2 610
Thanks.
From this, total was RM1996 (that was October 2009, I guess price would go up a little bit by now?)
I am getting the same for RM1500 in UK. Just thinking now if I have the money...hmmmm
Also do you need the caliper kit also?
Gerald 5;447439 said:
Did the below in 2 different occassion this month, anyone knows the price for ori front brake disc and pad? Am i slaugther?
E39 530i
Brake Pad ori- 560 for a pair
Brake disc ori- 580x2= 1160
labour-60
total 1780
This was thr price I paid for..
The feedback from the forum said it is "very unreasonable" . This is a workshop price and not directly fro dealer.
E39 530i
labour-60
total 1780
Looking at that...the one that I can get in UK is cheap but not that cheap..probably about the same price.
Probably just wait to do it in Msia then? How much if not ori one?
Thanks for that bro Gerald5
hello brother, the price that you quoted was for front and rear...mine is only front leh
Wah lau..........I missed the 'front only' part'. Even I would say that was very unreasonable....you got slaughtered man
Hmmmm...based on that...the ori part I'm getting is really cheap then. Have to think about this really hard..
My steering rack is leaking both sides, left and right. I need to look for rack. Cannot repair with repair kit because the shaft is scratched. Anyone know what's the current/market price please?
Changed one unit of lower arm (Lemforder) for RM 360 inclusive of labour.
I was told the recon unit is around RM 1300-1500 while new is about RM 2500
Read somewhere that try not to use the recon steering rack instead of the ori brand new one.
1. How many litres e39 525 M54 requires? 5w40 or something else?
2. What is the different between "change transmission oil" over "flush transmission oil". I just bought my e39 2 months ago and not sure about the history of the service so I would like to ensure the transmission oil is new.
3. What is recommended brake pad and how much will it cost? Should I skim the the rotor as well? If yes how much will it cost?
6.5L~7L
Change - loosen oil sump nut, let it leak due to gravity until no more is coming out and then fill new oil. You still have old oil trap inside some other places in the transmission. cheaper.
Flush - 1 inlet and 1 outlet from the machine and plug to your transmission. something like haemodialysis but you use clean oil to force the old oil out. expensive.
OEM brake pads about 200/pair. I would recommend changing to new disc(rm300+ each) if the disc is not in good condition. change the brake hoses as well.
Changed the cooling coil today. Bear in mind there's two types of coil for different year of built. Facelift (flat panel) and pre facelift (with tubes exposed). Total damage is Rm480 (Coil)+RM145(EV)+RM600(Labour) = RM1245/=.
IsaacVky,
Thanks. Do you think I should flush or change the transmission oil? I guess those who have some sticky or rough gear change will attempt to flush a transmission oil first before any other diagnostic. So far my gear change is rather smooth.
Are both pre & postlift coils priced the same? What brand is the coil? Ori?
Just to share with all after 10th month using UDM e39 528i...
parts are all ori or oem only...
March 2010
1st Repair ( broke down in ipoh)
tow back to kl rm 400
- Electric cooling fan rm 1,450.00
- coolant tank rm 328.00
- coolant tank cap rm 41.00
- coolant tank top hose rm 80.00
- hose clamp rm7.00
- engine thermostat rm181.00
- engine water pump rm 368.00
- fan belt rm172.00
- fan belt tension pulley(top) rm 78.00
- fan belt tensioner (bottom) rm146.00
- air cond belt rm 127.00
- air cond belt tensioner rm137.00
- coolant rm 35.00
-workmanship + reset system rm 240.00
2nd Time ( May 2010 )
Brake pads ( front ) rm 420.00 all in
3rd Time June ( Air cond Fault )
-Compressor Service rm 480.00
- Flush Hose & Condenser rm120.00
- Air cond Gas rm 70.00
- Air cond filter rm 180.00
- change suction hose ( union welding ) rm 180.00
- workmanship rm 120.00
1 week later aircond still giving problem take to EPF bawah pokok
- Change cooling coil , gas + labour RM1400
2nd Service
June 2010
- oil filter rm36.00
- air filter rm 40.00
- engine oil rm 374.00
- auto gearbox sump gasket rm 80.00
- auto gearbox oil filter rm 40.00
- auto gearbox oil rm 420.00
- rear axle oil 30.00
- workmanship + reset system rm 160.00
and now the latest
August 2010
** Tomorrow collect car from wshop will only know..estimate another rm2500+/-
fuhhhh belum campur brg2 lain like ice and other accessories yg dah invest..
BMW memang power....:)
March 2010
- hose clamp rm7.00
- fan belt rm172.00
- coolant rm 35.00
2nd Service
June 2010
and now the latest
August 2010
Aiyo bro u bikin gua takut la...mine so far not so many problems...only alternator kaput recently. What year is your car?
