JoeYazid
Founding Member
- Dec 29, 2004
- 1,507
- 38
BMW;296692 said:3. Repair EGS module = RM 500
Bro ..... what is this ..... how they repair this .... ?
BMW;296692 said:Recently reapir my car at subang beemerholic which cost me:
1. Wheel speed sensor front (L&R) = RM 380x 2
2. ABS module = RM 2200
4. New radiator = RM 710
Labour charge = RM 200
Next week have to change the front and rear disc break. And also break shoes
Oh my god! have to take awhile for recovery first.
Any body change disc break before? Mech said ori disc break very expensive. Any cheap and good quality OEM part available? and roughly how much it cost?
Now i am broke
BMW;296692 said:Next week have to change the front and rear disc break. And also break shoes
Now i am broke
JYazid;296772 said:Bro ..... what is this ..... how they repair this .... ?
bmw7833;296780 said:Use ori disc..Last time i use non-ori one, only two mth, my steering shake again!!
Y814YOA;298698 said:Hi Guys,
New to this forum. I brought back my 525i 2001 from UK. Had current leak problem after few days out from container in Port Klang. Sent to Auto Bavaria JB and replace lots of stuffs, which I think not relevant, but nvr argue with them. Cost me around RM15K altogether but problem not solved. Fed-up, send to Seong Hoe Melaka, met this Ah Swee guy and he trouble shoot the problem. And cost me only RM300+ because of the bl***y heat resister. Moral of the story, Auto Bavaria is useless and ripping me off. From then on, I only send to Ah Swee even though have to travel all the way from JB to Melaka. Long live Ah Swee (btw, his quite old, almost 50 already, but experience wise, no doubt at all).
BMW;298703 said:EGS module is a electronic chip that control gear shifting for the gearbox. Mine got some small small component burned, so just repair it. cost me RM500. Now everything ok dy
Jerman;299850 said:Welcome home and welcome to the Club. Care to share what leak problems you had! Initial bill of RM 15k, wow!
initialM;298973 said:Last time my crankshaft sensor spoilt after servicing. Thank god I aleady bought in SG & kept in the boot. If not easily cost RM400 +++
There r few BMW specialist in JB. No need to go to Malacca:smokin:
bmw7833;299748 said:What is the syndrome that made you repair the EGS module??
BMW;300541 said:Because of the gearbox cannot change gear all the time...Keep using 3rd or 4th gear all the way. So send to mech, he found out it's EGS module gone, so he send it to somewhere n fix it.
Y814YOA;300496 said:Just came back from Seong Hoe last weekend, replace steering rack; cost ard RM1K, not so bad. I heard it is a known pblm for E39 to replace steering rack. :burnout:
JYazid;299621 said:You mean the EGS ECU could be repair ? They open the ECU and change the proms ?
YAzid
Jerman;296929 said:bro,
Sorry to hear about your recent repair/maintenance costs.
Original Brake Discs, Front=RM 580 & Rear=RM 520
OEM Front=RM 290 & Rear=RM 230
Good luck!
Jerman;300558 said:Y814YOA & bmw 7833,
bro,
Yes, E39 steering rack is infamous for its leaking. New ones cost about RM 2500k while re-con ones between RM 1200-1500. I "repaired" mine for RM 500.
