e34 Parts and Maintenance Cost
tehyw;684351 said:
bro, ur rims are damnnice loh!! wherr to get?
Thanks for the compliment. I got it used from Jooi Seng Tyres in Klang. The rims came from E38.
My rims are BMW style 32, 18x9" and 18x8" staggered. The tyre shop has lots of used rims for BMW.
Does it fit 245 tyres?
AND how much did it cost u?
alternator kaput.sent my car to autopex glenmarie.
change recond alternator (for e39 model) = rm600
labor = rm100
labor = rm100
e39 alternator stronger ah?
no lah.it because they have no stock for e34 punya.but they said it can use coz i checked the mounting,pulley, and ampere rating is just the same.
perhaps sifus here has another opinion?
air-cond prob..so, damages:
1. receiver dryer rm135
2. gas/labour charges rm45
total= rm180 +1 day @ workshop
brake pad changed..
front - jurid -rm129
rear - jurid - rm100
labour - rm 70
replica ACS bodykit ( fiber... :) )
front half bumper
rear half bumper
right and left skirting
Total damages rm750(include nice installation)
feisaldzul;651 said:
A/C belt - $20
ABS Sensor RHF RM 380
absorber dampers = 35(front), 30 (back)
Absorber front RM290/rear RM280
Air cond. filter RM184
Air filter - RM48.00 (my filter got dirty after i took my car into Ladang Sepang during the Malaysian Rally!)
Air Filter = RM33
Air Filter RM 33 - RM 45 - RM 75
Air Filter RM 35
Air filter RM75 (dunno why costs more than M20 air filter)
Air-Cond belt M20 RM 20
Air-cond compressor RM 1600
Air-cond gas RM 30
Alternator (Bosch@115A) = RM1350 (the original was already 14yrs old).
Alternator(potong kereta) RM 400
Anti-roll bar tie rod (Ori) RM 100
Auto gasket RM 50-60
Auto gasket RM50
Auto gasket RM60
Battery ( Maintenance Free ) - RM275
Battery ( Maintenance Free ) RM 200-275
Battery ( MF GP) RM152
Blower fan - RM140 (2nd hand)
Blower fan (2nd hand) RM 140
BMW Coolant - $22
BMW Roundel - RM 30 ( hakitrade )
BMW Roundel RM 30
Body Moulding Clip RM 3
Boot Compressed Spring (1pc) RM 57
By-pass hose RM205
By-pass hose RM205
Camshaft sensor = 320
Camshaft Sensor RM 320
Castrol RS 10W-60 RM120 per 4-litre x 2 (bought from PJ)
Center black grill (about 1.5 foot wide) - it's on the inside, excluding the chrome kidney frames RM83
Center black grill (Internal) RM 83
conrod bearings = 100
Conrod Bearings RM 100
Coolant level sensor : RM76 part, RM10 labour
Coolant RM 22 - RM 25
Coolant RM25
Cooling Coil RM 1100
cylinder head screws = 170
Cylinder Head Screws RM 170
Door Seals (Inner stuck to chasis, per piece) RM 258
Drive shaft cv joint boot - RM 40/piece
Drive Shaft cv joint boot RM 40/piece
engine bearings = 80
Engine Bearings RM 80
Engine Oil (Full Syn 4L ) RM 110 - 130
Engine Oil Thermostat RM 67
Expansion valve = 140(original), 110 (mercedes)
Expansion valve RM 135-140
expension valve - RM135
Fan belt - $20
Fan belt M20 RM 20
fan clutch = 300 (behr)
Fan Clutch RM 300
fan cover = 110
Fan Cover RM 100
Front Absorber Damper RM 30-35
Front Absorber RM 290-320 per piece
Front absorber top mount - RM430 (gila punya harga )
Front Absorber top mount RM 430 (gila punya harga )
Front bonnet Heat Insulator RM 290
Front Brake Disk (1 set) RM 420
Front Brake pad - RM 130
Front Brake Pads RM 130
Front Wheel Bearing RM 290-320
front/back brake pads = 125 / 110 (Jurid)
fuel filter = 80
Fuel filter RM80-95
Fuel filter RM95
Fully synthetic oil RM110 for 4 litre
Fuses RM 2-3
gas - RM30
Gasket RM28
Gasket RM28 (dunno which gasket)
GM solenoid valve (in A/T) RM 120
Halfmoon seal (below the gasket) = RM5/ea. (you'll need 4)
Halfmoon seal (below the gasket) RM5/ea. (you'll need 4)
head gasket (thicker than normal) = 220 (victor reinz)
Head Gasket (Victor Reinz) RM 220
Headlights (Inner Lens) RM 225
Heater hose RM97
Heater hose RM97
Hi-rev 9000 (6 Litres) RM 218
hydraulic lifters = 60/piece
Hydraulic Lifters RM 60 per piece
Idling Valve RM 390
Intermediate Light Bulb (Bluish White) RM 30
Intermediate Light Bulb RM 6
Jurid front brake pads (Bava Auto) - RM115
K & N Air Filter RM 230
K&N air filter =230
Labour RM335
LH rear wheel bearing - RM95
low beam head cover/lense = 120 (hella)
Low beam headlight cover RM 120 per unit
Low beam headlights L - RM158.80
Low beam headlights R - RM158.80
Low beam headlights RM 158.80 per unit
lower arm (CTE Brand = 180, Lemforder = 230)
Lower Arm RM 180-250
LowerArm (like bimmer520/5i's Alu type) = RM250
Main Light Bulb H1 RM 22
Manual Gear Shift Knob RM 70
MF battery = 200 (century brand)
MF GP battery -RM152 at eunoss, one utama
Miscellaneous (clips, washers, etc) RM68
Mobil 1 (Full Syn 4L ) - RM130
Mobil One Engine Oil 8 litre 290.00
MotoMeter SpeedoMeter Gearing - RM160
MotoMeter SpeedoMeter Gearing RM 160
Muffler ring - RM20 per pc x 2
Muffler Ring RM 20 per piece
Oil filter - RM28.90
Oil Filter (Orig) - $35
Oil Filter (Orig) RM 15 - RM 37
oil filter = 15
Oil Filter 35.00
Oil filter RM 40
Oil filter RM37
Oil pressure switch = RM30
Oil pressure switch RM30
Oil strainer RM122
Oil strainer RM122
o-ring - RM30
O-ring RM 30
oxygen sensor = 650 (siemens), 550 (beru)
Oxygen Sensor RM 550 - 650
piston rings = 300
Piston Rings RM 300
plug Cable m20 - RM300
Plug Cable M20 RM 300
Power steering belt RM 16
Power Steering Hose = RM165
Power Steering Hose RM 165
Power Steering Pump - 2 types RM700/RM1100
Power Steering Pump (Type1) RM 700-1100
Pro-Shaft Coupling RM 105
Pwr steering belt - $16
Q8 Formula 1 10W-50 full synthetic - RM32.50 per litre x 7
Radiator Coolant Level Sensor RM 76
Radiator RM 700-1100
Radiator RM1100
Radiator RM700 osso can be bought (BEHR)
Radiator sensor RM 270
Rear Absorber Damper RM 30-40
Rear Absorber Lower Spring Pad RM 30
Rear Absorber Mounting RM 90
Rear Absorber RM 280-300 per piece
Rear bonnet rubber RM 120
Rear Brake Disk (1 set) RM 300-330
Rear Brake Pads (4 pcs) RM 160
Rear bushings (on support arm) : RM294 part (1 pair), RM30 labour
Rear Bushings (on support arm) RM 294 / pair
Rear disc pads (four pcs) RM160
Rear wheel bearing - RM90
Rear Wheel Bearing RM 90-95
receiver-drier/filter - RM170
receiver-drier/filter RM 170
Redline D4 Synthetic ATF (1 Quart) RM50
Redline D4 Synthetic ATF RM50 x 4 quarts (bought from Autobags)
Reverse Light Bulb RM 6
Rubber Boot 25.00
Rubber Mats (1 set) RM 75
Silencer box (from the 2-page-ad-shop in motortrader) = RM320
Silencer box RM320
Spark Plug 108.00
Thermostat = 45
Thermostat RM 45
Thermostat RM67 (for engine oil temp)
thrust arm - 260
Thrust arm - RM200/piece
Thrust arm bushing - RM 65/piece
Thrust arm bushing - RM60
Thrust Arm bushing RM 60-65 /piece
ThrustArm bushing = RM65
Timing bearing - $55
Timing Bearing M20 - RM50
Timing Bearing M20 RM 50-55
Timing belt (Orig) - $ 175
Timing Belt M20 - RM 50 (cheapo) RM 150 (quality)
Timing Belt M20 (cheapo) RM 50
Timing Belt M20 RM 150-175
timing chain = 110
Timing Chain M50 RM 110
timing sensor = 300
Timing Sensor RM 300
Track rod (aluminium) RM 270
Track rod RM 270 (aluminium)
Upper / Thrust Arm RM 195-210 / unit
UpperArm (ThrustArm) = RM210
used front foglights +3pos switch+4leg relay+fuses = rm300
valve cover gasket = 80
Valve cover gasket = RM25
Valve cover gasket RM 25
Water hose (fr thermostate housing) - $40
Water hose (fr thermostate housing) RM 40
Water hose (fr water pump) - $80
Water hose (fr water pump) RM 80
Water Pump - RM120
Water Pump - RM120
Wiper Blade 90.00
Wiper Rubber RM 40-45
ZF 5hp-18 repair kit = 850
ZF 5hp-18 repair kit RM 850
how updated is thsi price list? thansk.
Dear forummers,
I am looking for oxygen sensor. I looked at the list and it is priced between $550~$650. There are 2 types (Beru & Siemens).
I have 2 questions here:
1. Whats the difference between Beru & Siemens?
2. Where can i buy the o2 sensor at that price. (Auto Bavaria quoted me $1300 for o2 sensor.)
FYI, my car is a 1994 e34 with M50B25 (without vanos). I have been getting bad fuel consumption and i strongly believe that the o2 sensor is the culprit. My engine is in good condition and my idling valve is working perfect. Car mileage is 260,000km and o2 sensor has not been changed before.
Thanks and hope to get some advise from bros here.
Hi guys need help, im looking for 1 set of piston rings for 89-E34 +.50 (84.480 mm) anybody knows where can i get one, need it desperately i miss driving my car
buy my stroker kit, u will like ur car even more... hahhaha... piston rings, but new la... AB? or others...
Big! Thanks to Feizaldzul I just got the piston rings from Eng soon here in Singapore got some left for water pump so i got a new one for a hundred dollars too good deal too.
Work done at Naidu's last week.
1. Cooling coil (copper) - RM690
2. Expansion valve - RM180
3. Receiver/Dryer - RM165
4. Compressor - condensor hose - RM89
5. Compressor Oil/Gas - RM80
6. O-rings - RM35
7. Labour - 180
Here are my recent damages:
(Group buy)
VANOS Seal (thanks bmw7833!) RM100
(Spareparts Shop)
Valve cover gasket RM65
Rubber Seal (little round ones) 15 X RM3 RM45
Oil Filter RM16
Spark Plugs 6 X RM8 RM48
Fuel Filter RM28
(Workshop)
Engin Oil (Semi-Syn Ravenol) used 7L 10L X 25 RM250
ATF Oil 5L X 45 RM225
ATF Gasket + Filter RM130
Labor
(VANOS seal repair
+ ATF Oil Change
+ Engine Oil Change) RM260
Total RM1,167.00
Driving Pleasure ........ Priceless (or at least that's what I tell myself)
