c-square;787531 said:What I find most disconcerting and annoying is that when I ascend or descend a slope (20 degrees), ie the ramps going up/down car parks in condominiums, office blocks, shopping complexes, the gearbox seems to be "hunting" resulting in sometimes being too high especially so when climbing the slope or too low especially when descending. Occassionally, there were a "pull-and-release" jolt when foot is gently depressed on the brakes during descending at tight corners at the carpark.
I don't know whether this is a typical symptom of a turbo engine or not. When I complained to the SC, that fellow said that this is normal for a "low-gear-high-torque" engine....but I think this explanation is full of ballooney.
Akhie;787510 said:Went to AB KL this morning.
1) they dont have stock of the rusty seat part, so based on their SOP reply, "Have to order, will come in 2 weeks and we will call you once its here" stuff;
2) the gap between the dashboard and AC panel is actually a design characteristics to allow for easy access to pry open the AC panel. The infamous cabel is not a cabel afterall, it is actually the red panel revet hole, i.e. the red lining in the Sports models. If you dislike seeing the red thingy in between the panels, you could ask them to paint it.
Just to share.
Morganl;787428 said:... escalating this directly to BMW Msia MD would definately help you to have a better chance to get a loaner car.... I got mine arranged within hours after my phone call ended with the MD office...
jan999;787559 said:the luxury line is ok. only sport line affected i think
silvy;787560 said:So, it is actually normal for sport line to have a improper alignment between the red trim and the panel resulting in the gap?
MarcoMeswara;787553 said:Bro, yr call reached the MD office...
The only BMW Malaysia contact info i have is from their website ;
BMW Malaysia Sdn. Bhd.
P.O. Box 112,
43007 Kajang,
Selangor Darul Ehsan, Malaysia.
BMW Voice
Toll Free (Local) 1 800 88 3000
Tel (International) +603 2082 0000
Fax: +603 2082 0082
Its good you reached the MD... ada nombor lain ke ? Or was it your good luck that the secretary connect you in ?
Akhie;787616 said:Based on design, i is properly aligned. If u look at the extreme left of the panel, it is aligned. The SA took it out and brought it to me. If they can even align the AC side of the panel (dunno if thry can even do so), then the other side wud not be aligned anymore.
ACS325i;787640 said:actually where is this gap ar? For the life of me i can't figure out if mine is aligned or not and am a bit paranoid now haha
