1st E36 on bbs style 5 in M'sia
xtracooljustin;504169 said:
Bro, looking sweet in Style 5. Itu BBS sticker u mau kasi lekat mana?
it's sticked on the lip bro ...wait till i get the close up picture of those ....
some pictures from the fraser hill drive ..thanks mizhan ....
ICEMAN 13;505103 said:
maxxsp ..you ride is even better than mine ...love ya big brakes ...
yep got the tips replace at JFA ... size is 4"~4.5" if not mistaken ....
thanks for the info :top:
will check it out at JFA.
ICEMAN 13;501176 said:
getting there
bro...what brand is this...is this the ori one modded the tip only or u replace it? what is ur advice if i want to replace my single vanos machine exhaust with some vroom..vroom exhaust?
it's the original back box undergoing a surgery ...you may pack the box according to what sound liking you want ..silent , noisy , basey ....
as for the tip , is just a normal tip ... no brand for that ....
want to have some vroom vroom sound , then just repack it and tell them you want more VROOOOOMM VROOMMMMM
vincent;516124 said:
how much did jfa charge you for this repack ? and what sound u opt ?
not mistaken the cost was somewhere around rm 280 ~ 350 ...sound wise i opt to mid base ....
what about a blade inside the tip...u throw away ka? coz mine got a blade..can move left right..
bro..u replace the two tip ka bro? you sarong or cut old tip and do welding new tip to the box?
my list of engine makeover
2009
1) weicher front strut bar
2) Racing dynamics F&R Anti roll bar
3) Bosch blower motor
4) AC expanion valve
5) AC drier
6) AC micro filter
7) Gear lever bush
8) Gear lever shifter bush
9) Gear lever shifter cover
10 ) engine mounting
11) Original Flywheel oilseal
12) Top exhaust manifold gasket
13) Bottom exhaust manifold gasket
14) Vanos gasket
15) used vanos repair kit
16) inlet gasket
17) Thermostat + O-ring
18) Oil filter Housing gasket + O-ring
19) Semy SYN engine oil 10W 40 Silver
20) Oil filter
21) Spark plug
22) Oil sum gasket
23) Water pump
24) Engine belt
25) AC belt
26) Power steering container
27) Used M52 valve cover
28) Rear pipe flange
29 ) Rear pipe gasket
30) Gear lever welding work
31) dashboard bulbs
32) Fuel hose
33) Manual 85W90 Trans fluid
34) Long shaft center bearing
35) Valve cover gasket
36) Clutch master pump
37) Clutch piping
38) used glove box
39) Brake fluid DOT 4
40) Auto dex III transmission fluid
41) R134a full re-fill
42) Pedal bush
43) Flywheel bearing
44) AC tensioner
after the run-up 1st service 2009
1) Fully Syn Engine oil ( TOTAL ) 10W50 Gold
2) BMW original filter
3) Fan blade
4) BMW original coolant
5) Air bellow
2010 new items
1) Fully syn engine oil ( TOTAL ) 10W50 Gold
2) BMW original oil filter
3) Vanos oil pipe
4) front top mount
5) Front ABS Damper
6) Rear ABS damper
7) Rear ABS tube
8) fog lamp bulb H1 12V 55W
some works done lately ...
changed the top mount and the abs shock stop damper
damaged mount and damper
empty mount block
installed
clutch work
forgot to take more pictures ...as went off for TT ...enjoy
im sure you realise the new top mounts, increase in ride height... i changed mine also last year.. according to BA, the new batch all comes like these... anywer to get the previous types new?
btw, you have done a great job bhai...
