Received a bunch of parts to fix my pedals.
Rubber pedals, new accelerator pedal, throttle cable and new bushings for all of them.
Accelerator pedal out
Didn't really like the M pedals already on the car
What was left of the old bushings. Accelerator pedal felt crap, wasn't smooth.
Because the bushings were worn/missing, the pedal was hitting the metal bracket that it sits in. This is the damage
New bushings
Modified an old clutch pedal bushing so that the new rubbers on the accelerator pedal don't get damaged like they did before
Everything fitted
Accelerator feels tight and smooth now, definitely give these parts a look if your accelerator feels crap.
Brake pedal
New rubber pedal
Old bushing
New ones
Clutch
Bushing removed
AKG delrin bushing
Old vs new bushing
Because the AKG bushings are made to such tight tolerances, they were really hard to fit because they are oversized. Had to remove them a few times with a lot of cursing because the circlips wouldn't go on as it was so tight coupled with lying down on the drivers footwell looking up with limited lighting... Install of only the clutch pedal bushings took about 2 hours. Was the pedal feel worth all the work? I believe so. Clutch feels really good now with absolutely no play at all. No more squeaking! :top:
