wan e46;769430 said:thanks sifu astroboy for the reply,
by the way.. im really not familiar with BMW Engine..Can u give more explaination with picture ( maybe )..what a different of M43 engine and N42 Engine?
its N42 is 1.9cc with 4 cylinders and M43 is 2.0 6 cylinders?
really2 need your helps all my frens and sifu
astroboy;769433 said:M43 is the 1998~2001 318i 1.9L E46 engine. Facelift 2001~2003 E46 318i using 2.0L N42 and in 2004+, E46 318i using N46, a slight improvement over N42, but 99.99% parts sharing.. All 4 cylinders.
E46 320i is using 6 cylinders M54, 2.2L.. 170. That's different class.
http://en.wikipedia.org/wiki/BMW_3_Series_(E46)
teighlour;769407 said:Hi wan e46, im driving the e46 N42 y2002. If you talk about standard maintenance, the cost is about RM200-300. Off course my car is already 10 yrs old and standard wear & tear maintenance of the car goes from hundreds to thousand plus to replace worn out parts. So far touch wood, my car hasnt got any major headaches at the moment but i am always prepared with extra cash if that happens. You can go check out the thread on maintenance where other sifus put up their cost of servicing from various workshops.
astroboy;769445 said:It's M43, not M42.. :4:
This is N42/N46, black plastic intake manifold versus the above metal:
E46 320i is using 6 cylinders M54, 2.2L.. 170hp. That's different class.
N and M engine difference? Huge horsepower, fuel efficiency and technology difference. M43 no Vanos, no Valvetronic, use accelerator cable instead of wire, etc. Imagine Honda no VTEC versus VTEC.. :4:
tweiboon;769453 said:Are u sure M43 is build between 1998~2001 ? M43 is using timing belt. My e36 1993 318 is using this engine. If this M43 used in e46, is that meaning e46 using timing belt ? As far as i know e46 never use timing belt.
wan e46;769448 said:haha....its my mistake sifu astroboy..yeah its M43...
tq so much for the picture..so rite now i know which is M43 or N42/N46 engine..
bro astroboy , its any thread in this forum that discuss bout the M43 engine?
so i can refer and read to gain the knowledge bout this engine and maintenance
thanks a lot bro :top:
astroboy;769460 said:You are in luck. Please refer to QD250: http://www.bmwclubmalaysia.com/forums/showthread.php?55-E46-parts-amp-maintenance/page126
His M43 bungkus many 6 cylinder siblings in a legendary drive to Putrajaya.. many till today still can't believe their eyes.. :4:
waaaaa..how come that 4 cylinders kan "tapau" 6 cylinders bro???...where workshop did he send to mod?...hehehe
E46 N42/N46 using timing chain.. please refer to the wiki link I provided above for the exact year of the E46 model.
astroboy;769499 said:My mistake... M43 all using timing chain.... the photo I show above is not correct (M40).. M43 is this:
1999~2001
