aidilj
Official Member
- Jul 3, 2010
- 2,291
Hi Guys, a little sharing on how to turn recirculated air memory function on using DIS/GT1. Info on how to install DIS is here http://www.bmwclubmalaysia.com/forums/showthread.php?40618-EasyDIS-44-and-INPA-working, or if you are at the mechanic's to diagnose, might as well jump on him to get this done. I a few times had forgotten to block outside air recirculation, and passengers teased me for messing with the vehicle too much.. while in reality that was the default behavior. :stupid:I may have missed some screens in the process so please bear with me. When doing the actual programming, I had to turn the key to ACC/position 1 and program, not as the screen instructed (ignition off and on again). Probably related to the interface in use. Hope this helps somebody...CheersAidilLaunch DIS and click on Coding/Program. This button only available to v44 not v57
Click on car memory
Connect interface, turn ignition on, and click the right green button
During my autodetect, this error pops out as the factory radio was removed for obvious reason. Click yes
Autodetect runs again and comes this screen, choose HVAC (number 8)
Then choose flaps then recirculated air memory
Mine was not activated
Activate then check the same page, note that setting are not written yet
Go back to main page car memory page, scroll down and choose set vehicle
This page summarizes changes you have made and will be written
Here is where I need to turn switch to ACC/position 1 to program, toggling ignition doesn't work, click yeshttp://i791.photobucket.com/albums/yy197/aidilj/ihka/20.pngSuccessful programhttp://i791.photobucket.com/albums/yy197/aidilj/ihka/21.pnghttp://i791.photobucket.com/albums/yy197/aidilj/ihka/22.pngDoublechecking, guess the asterisk shows the default factory option. Have fun!http://i791.photobucket.com/albums/yy197/aidilj/ihka/23.png
