mike_cwlee said:Thanks for the tip. My first time there hence used their stuffs.. Would allow if you were to bring your own stuffs? Ie purely labour / service charges?
Concur with abang gendong. Build the relationship and you shall see the difference. Anyway, I do recall that Optimum doesn't allow you to bring your own parts.gendong said:don't just look at what is being paid for if its ur first or second or even third visit. build a relationship with ur mechanic, then u'll see the difference it makes.
Check out Quill or Wearnes. Should be around RM7k range.phonzy said:finally after owning my 320d for 2 years i've decided to put on the power kit..
does anyone know anywhere that gives a good deal and how much the power kit cost now so i can go do some comparison and haggling?
cheers!
That is a very heavy oil to use on a 320d. Do you feel that the car is sluggish?mike_cwlee said:Hey dudes.. Just did a service in Optimum. So just FYI on the charges.
Ravenol 10w60 RM285 (4li) needs 5 (they only stock 10w60 variant for Ravenol
ATF Ravenol Dex3 RM69/li needs 6
Oil Filter RM105
AT oil pan RM 445
AT adaptor RM94
Inspection and svc RM180 and... Ada service tax
have actually asked a dealer in setia alam and there are stocks for e90 variant.. about RM 8.5kphonzy said:finally after owning my 320d for 2 years i've decided to put on the power kit..
cheers!
I cant exactly feel the difference honestly. But then I did poured in a bottle of Tufoil... probably compensated for it someway...Mavik said:That is a very heavy oil to use on a 320d. Do you feel that the car is sluggish?
Can't really say got any increase, maybe very very little.FZainol said:Anyone changed their air filter to aftermarket on their D? K&N, Jetex etc...any performance increase or problem after install?
Congratsphonzy said:2 years after driving the 320d.
and seeking opinions and getting poisoned by forums and Whatsapp by the gurus and sifus.
i've finally
powerkitted + vector the ride.
previously was vector alone.
now i steam x 2.
Yes to replace, inspection can be done without withdrawing the whole engine. That is according to the BMW Service Advisor who informed me when they changed mine last time.ck82 said:Hi Mavik,
I thought that the whole engine needs to withdraw from the engine bay to inspect or replace the timing chain? I think I read it from other section of the forum. Please shed some light on this because I also like to know more about this.
Thanks to Wingzee for detailed explanations.wingzee said:ck82,
Permanent solution is to get the car checked & replace the following items under the warranty period. BMW has came up with revised versions of the parts in 2011. Badboyz3 & Mavik has got theirs replaced under warranty. An out of warranty job + parts will cost around RM7k at the SC, with chunk of the cost coming from labour alone (RM5k).
Timing chain (3), sprocket (3), chain guides (4) and chain tensioners (2)
It is however should be noted that fault is not the chain itself but excessively sharp sprockets which causes the chain to wear & fail prematurely. Excessively sharp edges were present on the sprockets, the chain does not flow evenly over the guides.
Engines affected are those produced from 01.03.2007 to 01.03.2011.
Of course one can always listen to the engine to check for potential signs but problem is unless one is an expert, what you hear will only be the diesel clatter.
