Mavik
New Member
- Jun 28, 2011
- 1,485
Sorry bro, all diesel owners here5010 said:hi guys.. need feedbck on 320i year 2005 jap spec ..pls
Get a 320d. 320i underpowered especially the non-turbo ones.5010 said:hi guys.. need feedbck on 320i year 2005 jap spec ..pls
Haven't experienced that yet, do let us know what might have been the cause of that issue.MRI675 said:Hi guys...any of you has this problem? My car still in the workshop since morning and they still figuring out the isues.
http://i1314.photobucket.com/albums/t568/ropeque/b28611fc-cfd5-4db5-9524-bd82059b7739_zps82122e58.jpg
Will do. Sent my car to M1 Segambut and they still haven't found what has caused this...Mavik said:Haven't experienced that yet, do let us know what might have been the cause of that issue
My fc is getting higher too, from the initial 6.4l/100km to the current 7.4L/100km after 3years. I wonder what could be the problem. I also like to ask since I just finished my warranty period, how often should we change our engine oil? Some said 7-8k km, some said ard 10k km. which one to follow?Mavik said:That is rather high, I am getting on average around 8.0L/100km and that is pure city driving and getting stuck in traffic jams.
I change mine around 8000km as I track my car, so the more frequent oil change. Otherwise 10-12000km is fine as well.Lovehewit said:My fc is getting higher too, from the initial 6.4l/100km to the current 7.4L/100km after 3years. I wonder what could be the problem. I also like to ask since I just finished my warranty period, how often should we change our engine oil? Some said 7-8k km, some said ard 10k km. which one to follow?
I managed to hit 5.8 L / 100 km during my last drive to Bidor, and that was with heavy traffic too.Lovehewit said:My fc is getting higher too, from the initial 6.4l/100km to the current 7.4L/100km after 3years. I wonder what could be the problem. I also like to ask since I just finished my warranty period, how often should we change our engine oil? Some said 7-8k km, some said ard 10k km. which one to follow?
Thanks, I'm worry to get a 2nd hand unit actually but couldn't afford to get a new one yet.Lovehewit said:I just finished my warranty so I'm not able to give you a precise maintenance cost, but from what I'm told, changing the lubricant should be around 600+ included labour fee. I think the most important thing to check is the engine, service records if any (I would advice get the one with proper track of service record, you can even call up the service center to verify), the overall car check which you can do by bring the car to see a trusted mechanic (check if there's any accident before, leakage etc). Hope that helps.
A standard engine oil change plus filter can be around in the RM500+ range depending on the brand of oil you are using. Some opt for the more expensive oil and some decide to go for the cheaper ones so that is a main factor as the car will use 5L of oil.kockroach said:Dear all sifu, am considering to buy a 2010 E90 320D, can I know what are the thing to check and what are the maintenance cost to be expected.
Thank you.
Get the car inspected at any reputable mechanics or service centre (Quill, Wheelcorp, Wearnes), cost less than RM200 for full inspection. The report should be able to tell of any faults with the car.kockroach said:Dear all sifu, am considering to buy a 2010 E90 320D, can I know what are the thing to check and what are the maintenance cost to be expected.
Thank you.
Most of the parts you are able to get them cheaper direct from stockist.mike_cwlee said:Hey dudes.. Just did a service in Optimum. So just FYI on the charges.
Ravenol 10w60 RM285 (4li) needs 5 (they only stock 10w60 variant for Ravenol
ATF Ravenol Dex3 RM69/li needs 6
Oil Filter RM105
AT oil pan RM 445
AT adaptor RM94
Inspection and svc RM180 and... Ada service tax
