Honey,i blew up my engine
pussy said:
Finally.. after much tought and consideration, i have decided to go for a M50B25 non-vanos with a jacto 5-speed box.. checking around, says it will fit.. now wondering other stuff will be able to fit in..
M50 is much of my choice, since so well versed in it..
will start another thread on the conversion..
will keep everyone posted..
Any reason why you choose to go with non-vanos ? :confused :confused:
I suppose Vanos is better in performance.
izit due to technical issue that restricted you ? Mind to share here.....
535i said:
M50 ? Get ready to be tapau-ed laaa .. :D
the idea is not to beaten by the higher cc cars, cos this for my daily usage now, hence the petrol and road tax.. if it was my other driven weekend car, then i would have'd gone for a v8 engine..
as for the 'tapau' session, i will bring the black monster with me..:D
the vanos engine is quite complicated, to make it work, couple of sensors would need to work in conjunction of the auto gearbox, note, the vanos works under load.. under idle it dosen't.
also, the non-vanos has higher cam, more to pulling power..hehehe:p
so ..... you mean BMW engineer invented VANOS for nothing la ..... or you are better knowledge that those engineer ..
Pro dun just taruh people like that lah. :D :D
If you disagree, mind share your knowledge with us....pls !
This is all abt why have this forum.....sharing, caring, helping, gathering, communicating, etc.......
yeah rite ... 'daily usage' la konon ....
Petrol and rtax ? Puhhh leeeeassseeeee ...... That can be adjusted, no ?;) ...
Ur black is a monster meh ? :p .... Sure u can do better than that ! :D
ah lian said:
JYazid,
my teh trolley can go fasterer wid vanos or not ahhh....?? :p
Mdm Ah Lian,
Pussy say that you need to upgrade the brake to 4 pots clipers first, only can put vanos ... heheheheh.
JYazid said:
Mdm Ah Lian,
wid the 4 pot calipers, i need to upsize the rims and tires lar....
later the bosses complain of skid marks on the carpets lar.... :(
Ye lah tu ..... wanna to test power .... come lar .... this early Dec, Bailey is waiting and the Doc might joining also, Sifu XXX will follow from behind ...... meh le .... takut ke .....
Boleh ikut - tapi aku balik nanti - bapak aku tak mengaku anak !! :(
Brader, please excuse him la..give him a break...he is having a bad dose of hallucination kakaka:D
the vanos and non-vanos has both it's advantages..
vanos is for cam optimizing for better torque range and power.
non-vanos is tuned for power minus the variable timing..
did you that the vanos inlet cam duration is 225 duration, where else the non vanos is 240 duration. but bmw engineers designed the vanos with better torque and similar power even with the lesser cam duration..
aiya.. even the double vanos e46 and the non vanos e30m50 can keep up with each other.. i believe one was tailing the other.:p
so it means the e30m50 vanos can ta pau the e46 double vanos issit?:eek:
Huh ? And where does the OLD BIG SICK comes into the picture ?:confused:
Haiyaaa .. too technical laaa . dun understand .... :D
Bottomline - ur black cat vs my black cat .. how ?
hoi pussy, at that time, i didn't know the way to temerloh ok....... so, no point leading the way. plus, the old mercedes benz was blocking the way......by the way e46 is a crap car regardless what kind of cc u put into that car. u can kutuk any e46, i will sokong u kau-kau....:D
DmC said:
pussy,
since u r changing engine with gearbox as well..
Is your old 4-speed auto gearbox can still be use?
If yes, mind selling it to me cheap2..
hehehehe...
PM me yeah..
sure or not gonna buy.. then janji janji.. last cancel!!
:p
