E3six
Senior Member
- Dec 8, 2004
- 442
ALBundy said:My friend didnt like the surge in power![]()
Too fast too furious
Hoi,
you change my statement ar !!!!!!!
pussy said:aiya... i m so cuntfused..
M30B35 with potato chips, B35 manifold... some more go turbo.. aiya, if turbo i sure not blow the engine...i would probely kill myself..400hps.. how to handle, even just got to handle my black monster inside/outside..
pussy said:just spoke to TJ.. drag on tonight.. location not known yet...
pussy said:535i.. i m quite prone to blowing up old engines.. this is the second engine.. first was my friend's e30 M20B20 L-jetronic.. engine parts was on the road..
with a tarbo B35.. there's more to the engine conversion.. need to upgrade brakes, springs, asorber, fuel pump, exhaust..some more, all this changed already..
535i said:Meow - I blew off 4 engine already ..... B35 .. The last one was last Raya .. balik kampung naik bas ... betul punyer story ..
But my 5 th engine (current) - fully done up - meaning - got it from chop shop - change ALL the internal parts, piston, rings, pumps, chain, bearings - u name it ..
Cost = 11K .
The engine is 1 year old already - the secret - no more 6,700 rpm.. only to 6,000 rpm ajeee ..
.. cukup laa .. The torque comes circa 3,500 rpm onwards ..
Pakai PIVOT lite laaa - cheaper than changing engine maaa ...![]()
asman said:patut la aku tak dapat test drive lagi keta ko 535i
asyik kaboom...hehehe
pussy..go for b35 je lar
u damn ganas driver must have ganas engine lor![]()
535i said:Enjin masih 'dara' laaaa ..
Sabor .. dun be gelojoh ..![]()
pussy said:was thinking of M50B25 engine to put in.. since i m well versed in m50's..
pussy said:Finally.. after much tought and consideration, i have decided to go for a M50B25 non-vanos with a jacto 5-speed box.. checking around, says it will fit.. now wondering other stuff will be able to fit in..
M50 is much of my choice, since so well versed in it..
will start another thread on the conversion..
will keep everyone posted..
535i said:M50 ? Get ready to be tapau-ed laaa ..![]()
