Abe Jak
- Dec 13, 2007
- 832
affan66;392638 said:find the MFM and download to your PC. unzip that file. create a folder called garmin in your SD card. If there is already a file in there, move that file to another location outside of the garmin folder. Then copy the file gmapsupp.img into that folder.
put the SD card into your GPS. then switch on the power and go to settings. Then go to map -> map info. You will see a list of maps. Select the top two in the list and unselect the rest, if they were selected in the first place.
Try it out. This worked for me until recently but I believe it has something to do with the map itself or my device.
done that bro..tapi map tak penuh...full map after select all the listed maps..will try again..isk
