jarance;426914 said:As least you dont have mechanical failure.. whew!!!
chetz;426935 said:luckyly ya.. but the solenoid kong already.. dunno is it really kong or not.. how to know bro?? foreman quoted brand new around 2.+k.. second around 1.+k... is it true?
jarance;426959 said:The solenoid can be tested without dismantling the gearbox. Any workshop with proper diagnostic tool can test the solenoids.
There 6 solenoids there. All kong at the same time?
chetz;426967 said:Owh.. if solenoid kong? whut's the prob? most prob i think all 6 kong.. just change gbox oil on friday.. flush it out yesterday.. it's all grey n dirty already.. does it becouse the solenoid kong? briefly mind to explain how the solenoid works.. if u dont mind...
do u know how much the solonoid will cost? second and brand new price.. thank u..
tenno;427355 said:Solenoid kong? It used to kong. It is one of the factor affecting GB mechanical. Ive made known that solenoid is used to control ATF fluid supply to GB. But it is not necessary all solenoids are kong. Brand new per solenoid is around RM400. If all your 6 solenoid kong, 4x6 la. Become 2K++. As mine not all kong. So i dont have to spent that much.
BTW how yours chetz? Done edy? Mine still not assembled yet though parts are there. Mech is busy cost his best friend past away. Huhu..
jarance;428071 said:I think you also have to remove the exhaust as well if you want to dismantle the gb.
Should be about 1.5 to 2 hours job.
chetz;426921 said:Last pic is the soloneoid.. Was been told its kong edy..
chetz;428174 said:ya.. i was asking about theh workmanship cost.. not the timing.. any idea bro?
jarance;428177 said:2 person to do the job. One hour RM30. Do your math.
chetz;429390 said:aite.. thanx..
btw.. mine, total bill came out like 3.2k....
tenno;430875 said:Hi chetz. yours done already huh. Since u said that no mechanical problem to ur GB, there could be electrical problem i guess. and since ur headlight doesnt flex up as well, do check on electrical part...wiring maybe.. just my 1 cent opinion. Sifus know better. BTW how much cost you service the valvebody?
