Fireblade;558304]Jarance said:Install on my E46.. take note of the smaller ring for the High Beam
Ade;558335 said:Does the smaller ring sits flush with the high beam?
ICEMAN 13;558338 said:how does it looks on an e36 ?? any pictures
ICEMAN 13;558432 said:silly Q ...if one of the LED burn off ..can the single led be replaced... ?
jarance;558447 said:silly answer: they are surface mounted and very tiny. You got to have a very steady hand, good eye sight and a good solder gun/solder lead to do it. :top:
Normally, it is not the LED that is blown but more likely the Printed Circuit Board (PCB) are cracked or the copper tracked are damaged. :listen:. I usually repair with a single strand wire if I find that the copper are open circuit.
ICEMAN 13;558452 said:thanks you sir
2nd silly Q ...as you've mentioned that it's not the LED that's more likely to be blown out , but do you think it can happen too ??
If yes , are we able to replace just the LED with a steady hand etc ...?
jarance;558458 said:and yes it can be replaced. only thing is where to get the replacement LED.. :listen:
ICEMAN 13;558460 said:yep ..that's the 3rd silly Q ...where to get it from ??
jarance;558461 said:Silly answer: where else lar.. Jalan Pasar off Jalan Pudu. :top:
hafeez;558488 said:wahh.. interesting.. but how to install?
im a bit fail about DIY ni..
QD250;558480 said:interesting....
reserve me a spot.... will throw in RM20 for your personal installation.... hehehehe
rsctan;558501 said:1 q, my lights are those projector headlights for e46 pre face lift. depo i believe. can i replace those existing ones with these smd?
