astroboy
Well-Known Member
- Dec 15, 2006
- 8,734
- 63
If valve seal rosak, you will be emitting white smoke in your tail pipe. If serious, u will have a wet tail pipe.
BMW SC are using special grade LongLife oil and is supplied in drum/bulk. So far non of the SC grade oil is supplied in retail 4L pack, except the 1L pack BMW oil (OEM Castrol). The Syntium sold by SC is Syntium 5000 LL (if not mistaken) and not available in retail pack. Even their Castrol LL or Helix LL is not available off the shelf.
And Mobil 1has lots of fake out there. Be careful!
BMWs;452712 said:...
On another note. Recently i follow my friend to Naza service centre as he had to overhaul his Naza Ria due to overheat. So while we were there, i noticed that Petronas also supplies engine oil to Naza and it comes in 4L packaging which was written Petronas Syntium 3000 5w-30 and at the back there was no BMW LL-98. So now i'm confuse.
1) Does Petronas make the same oil "Syntium 3000 5w-30" with 2 different packaging?
2) Our BMW dealers use "Syntium 3000 5w-30" without the BMW LL-98 specifications?
3) Petronas short change us without the BMW LL-98 certifications.
Cheers
