Hello my fellow UDM friends.I need some help and advice here. The amber engine oil light has been showing up again for the past two days while running on my BMW E46 318i.I don't see any leaks on the floor.I had the same issue about 2 months back and then I sent it for service about 1 month ago and the below items were changed / replaced:-vacuum pump-replace rear cover plate of cyclinder head-remove & install / sealing G or replacing oil pan-gasket-O-ring-HEX Bolt (M8x28.5)-gasket ring-and currently using Shell Helix Ultra 5W30I have not checked the engine oil level yet (will be checking it before I start the engine tomorrow).One more thing is when I took it to AB, those guys told me that the shaft seal and the fly-wheel needs to changed as well (will this cause the engine oil to drop?)Sifu's, can you please shed some light on this. Please advice.Thank you.
