mielo86
- Jun 3, 2011
- 219
astroboy;687266 said:That's bad.. should have stain somewhere, get a foreman to check your u.
1. Radiator
2. Water pump
3. Thermostat
4. Hoses, seals and connectors
5. Expansion tank
If don't notice from the front, hoist up the car and check the back of the engine.
item 1 n 3 change already, item 2 checked n no problem, item 5 also in no problem....the water problem got worse last September, before that have to change like only once a month..the mech in penang do some pressure test n since then the water problem has gone worse..the mech say water coming out from some where around the head (maybe gasket)...that why i think my water prob maybe related to oil lost also...my assumption is that the gasket already give way to the oil n water...just my opinion...so now need advise from sifus here whether i need or not do top overhaul??(some more note: the water only come out when the engine start)
