cyne said:
Just visited Titan absorber today. I was surprised that there are already 23 F30s fitted with their shocks. My B12 is getting noisier by the day. Sad though Richard can't give me back the early adopter price 10 yrs ago haha.., but I'm sold. Will be replacing it mid of next month. Anyone wants to buy off my B12?
Titan... On 39.... Ooh ooh yess my sweet ride.. Orgasmic!!!
Suddenly u will realise b12 is over rated...
bimmerholic said:
It's called the Final Stage Resistor Unit (FSU), also called the hedgehog.
Ooh oneof my pet hate off bmw aircon... Bloody fsu... For my 38... Alamak. ? Whole dash kena come out.. Worse still squaks after refit.. Now hoave to do all over again.. And apply rubber grease at every gap
wah...e38 must remove dash ah?adoyyyy....
i wud do this myself....leave it to the shop and they will install with a few bits and pieces left out!!!
yup, i did it myself with the very good help of a friend to remove my dash to replace the aircond blower motor. It started to sound like it had a rat stuck inside. squealing sound when turned on. Glad it's all over now.
Hi guys,
My door (passenger side) cant open from in and outside.
Suspect that the inner lock kaput already.
If anyone experienced this before, please help to share with me the countermeasure and the cost involved.
Thanks in advance..
Extremely hot air flow from foot and upper vent even at 22'C.
Replace a new hearter valve at Naidu's place.
Part: RM 783
Labor: RM 70
Guys I have leak on my torque converter oil seal, since requires gearbox to be dismantled planning to replace the fly wheel oil seal as well.
Might need buffer for ATF Flush should required.
Anybody have done, cost and parts required?
Done it in 2012
[SIZE=small]Flywheel oil seal[/SIZE]
[SIZE=small]RM 45[/SIZE]
[SIZE=small]Exhaust pipe gasket (2pcs)[/SIZE]
[SIZE=small]RM 20[/SIZE]
[SIZE=small]Gear box oil sump gasket[/SIZE]
[SIZE=small]RM 35[/SIZE]
[SIZE=small]Auto filter[/SIZE]
[SIZE=small]RM 65[/SIZE]
[SIZE=small]Gear box oil (Vaico 8L)[/SIZE]
[SIZE=small]RM 280[/SIZE]
[SIZE=small]Gear box oil seal (input)[/SIZE]
[SIZE=small]RM 50[/SIZE]
[SIZE=small]Labour[/SIZE]
[SIZE=small]RM 350[/SIZE]
keigoayam said:
Done it in 2012
[SIZE=small]Flywheel oil seal[/SIZE] [SIZE=small]RM 45[/SIZE] [SIZE=small]Exhaust pipe gasket (2pcs)[/SIZE] [SIZE=small]RM 20[/SIZE] [SIZE=small]Gear box oil sump gasket[/SIZE] [SIZE=small]RM 35[/SIZE] [SIZE=small]Auto filter[/SIZE] [SIZE=small]RM 65[/SIZE] [SIZE=small]Gear box oil (Vaico 8L)[/SIZE] [SIZE=small]RM 280[/SIZE] [SIZE=small]Gear box oil seal (input)[/SIZE] [SIZE=small]RM 50[/SIZE]
Mind sharing the workshop?
Urgently Looking for workshop at Simpang Rengam/Machap/Kluang...kindly msg me @ 013 9813344...pls help!
bro, i can recommend a workshop in batu pahat..text me 0127405039 khairul
Just changed the followng:-
a) alternator - RM700.00
b) actuator - RM160.00
c) rear windshield rubber lining - RM230.00
d) steering pump - RM850.00
e) filter - RM65.00
f) steering hose 2 pcs - RM155.00
add
g) labour - RM350.00
:motz:
Koyak habis this month
B) actuator - RM160.00
e) filter - RM65.00
add
:motz:
e) filter - RM65.00
add
:motz:
wah bro...alternator quite cheap @rm700.new? what brand?why the need to change the power steering pump?
mick123 said:
aircond blower was playing hide and seek over the past week. the blower starts and stops as it wished. problem was with the blower setting/resistor (something like that) and replaced for rm280.
hi mick,same here....at times it blows max wit min setting,at times it don't work at all.also there were times it runs even when the key has already been removed.bought mine at bav auto for rm175 and DIY....
the one on the left is the ori made in 1997 whilst the one on the right is the replacement unit....
moots said:
wah bro anakin...sudah bili ka e39.....
Ye laa tunggu abang punya tak dapat2.... :sleep: no, not mine laa..its my eldest brother, I cuma tolong service jer, tengok dalam youtube macam senang jer...cold start idling not nice, so I took out icv and service using throttle body cleaner...but not much improved...
