huskar3399;850114 said:3. what happened to your old rubber? can always use them back.
i changed only 1.the first one counting from the front coz the tip has disintegrated and torn...
sakaigun;851439 said:1. Plug coil: RM 1020 (car engine run like misfiring, problem solved after replacing this)
I think I kena slaughter liao, found in the forum that the plug or ignition coil cost about RM100/pc...
:banghead:
Ignition coil easily DIY so can buy and replace. You don't need to change all 6 when 1 fail. If you did keep the remaining 5 as spares. Just need to remove each ignition coil individually and the engine will run smooth to find the faulty unit.Alex5522;853366 said:wah..different of RM 1020 & RM492 was very big man..:banghead: you can buy another 6 pcs for spare lol...
chaiks;853547 said:Ignition coil easily DIY so can buy and replace. You don't need to change all 6 when 1 fail. If you did keep the remaining 5 as spares. Just need to remove each ignition coil individually and the engine will run smooth to find the faulty unit.
mick123;854328 said:aircond blower was playing hide and seek over the past week. the blower starts and stops as it wished. problem was with the blower setting/resistor (something like that) and replaced for rm280.
mick123;n1125378 said:finally settled for m-sport absorbers bought from BA. total ~rm2350 for F/R abs, mountings, dampers.
Thanks for your info Haywire.haywire said:sakaigun;851439 said:1. Plug coil: RM 1020 (car engine run like misfiring, problem solved after replacing this)
:banghead:
Plug coil for M54 is only RM82 each from BA. RM82 x 6 = RM492. If yours is M54 la...the older one more expensive.
At least you found soemthing cheap on the listcyne said:Your cooling coil is cheap.. What brand is it?
