I got some rattling noise. Probably from drive shaft coupling. Anyone know what's the price and how long to replace that ?
Coupling cost u rm120-rm150. I replaced mine on March.
Damonzero;633224 said:
Guys, lately my car has been making sound whenever passing thru uneven roads, and the steering also lost the firm feel of it.
What happened? my wild guess are:-
1) Steering rack
2) Absorber bush (lower arm?)
3) Worn spring
Advice appreciated!
that is bimmer
nitedevil;634981 said:
Bro, whr u got the nozzle ?
i paid rm178 for each side
Modified Taiwan one....just joking. It is from e36 nozzle. I have also replaced mine recently
1 set Windscreen washing fluid hose @ 138.00
1 pc Windscreen washing fluid pump @ 52.00
2 pcs Windscreen washing fluid nozzel @ 150.00 = 300.00
using the e36 nozzle. the e39 original nozzle is expensive coz it comes with heater. Did at Optimum.
keigoayam;557910 said:
I use Castrol SAF-XJ 75W/140(if i am not mistaken...left the bill at home). Actually it is recommended to replace the oil every two years especially if you experience any noise.So i just follow the routine.
I found an article saying the benefit of changing the oil:
1)Excellent high temperature, high load performance
Maximum protection against wear and noise even at continuous high temperatures, loads and speeds
2)Shear stable
Extremely shear stable, ensuring that its excellent properties are retained over very long service periods
3)Reduced operating temperature
Under high loads and severe conditions it can reduce axle temperatures which increase life of gears, bearings and seals
4)Low friction
Improved axle efficiency offering potential fuel economy improvements
Anyone can advise on changing rear diff oil? Do you guys do it?
1) Steering rack
3) Worn spring
Advice appreciated!
I'd check the lower arms, tie-rod ends and anti-roll bar links. Most likely tie-rod ends.
Changed rear power window unit RM350. Central locking actuator RM100. Both from used part shop. doesn't include labor.
Back from genting on 14/5/2011, just about 1-2km about to reach my house, heart a very loud "krok krok" sound outside. reach home safetly and check it out that the fan clutch has drop from its original place. put aside the fan clutch and start again and sound still appear. call up WP, he advise to tow the car to his place. the sound is from the water pump, this i have just replace 1 year back (germany brand). now have to change to original for batter secrue.
total damage RM813.00
workmanship RM80.00
Expension tank RM295.00
Original Water pump RM345.00
Fan belt and alternator belt.
tow truck (free) from insurance.
workmanship RM80.00
Wah itu fan clutch tanggal ka? Lucky you did not overheat the engine. thats why preventive maintenance is important
harbhajan;637219 said:
hai bro, what was the mileage, your w/pump failed.tq
Bro if u dun know the history better change new. It wont cost much compare if it fail. Yr 530 is a fast car bro.
How much do I expect to pay for these things (for a 530i):
1) Thermostat (around RM180 from this thread)
2) Valve cover seal (RM178 from this thread)
3) Oil filter body seal/gasket (dunno how much)
3) I replaced my oil filter casing gasket for RM 45. Labour to carry out the replacement was RM 120. My motor is M52B25 btw.
Labor lagi mahal gila dari part? It should be simple job I think
Was told by a mechanic today its quite a tedious job. Alternator and everything from the side needs to come out. He quoted me RM100 for the labour though.
A no brainer, but just would like to confirm that the oil will need to be changed together when doing this?
