bimmerholic;620252 said:Copy that!
Cheers.
davidtch;621245 said:Hey guys, how long does water pump last?
My water pump was changed out @ 100k. Water pump bearing jam & snap the fan belt last saturday. My mileage is 156k. In short, water pump last 50k only?
Thanks.
I think it is original pump. Workshop changed it for me. What is the lifespan between both?initialM;621346 said:Did you change ori pump or aftermkt?
seewai;621300 said:Problem "resolved" by itself, there wasn't actually a problem, just ignorance from my part, and (maybe bro bimmerholic's too hehe). I'll explain in detail at a later post, need to rush off to dinner now.
Oh ya, the "fix" was given by Optimum Jason. Memang best lah got a workshop sifu who also drives an E39![]()
bimmerholic;621516 said:That's interesting to know. Can't wait to have the "brrrrrr" resolve by itself. Freezin my ass off.![]()
seewai;621579 said:Ok no pictures.
What worked for me is to turn the temperature knob located between driver and passenger blower to center position, when you can see the WHITE LINE. Like this, the temperature settings would be able to be varied according to preference, driver side and passenger side, independently.
Used to set always at three bars BLUE or two bars BLUE (less cool).
If you still don't get it I'll snap the pic and upload at an undisclosed time.
bimmerholic;621721 said:Bro, are you referring to this pic below? [ignore the statement in the picture...i curi from another site]
I tried turning the knob to centre position to the middle position ( i don't see any white line though but instead one red dot above and one blue dot below; meaning it's in the middle)
Result: No heat whatsoever but the intensity of air coming out of the vent has reduced). I even tried leaving it at 3 red dots, and still no heat.
bmw7833;622523 said:Someone is selling the HVAC for RM295 only.
http://www.mudah.my/BMW+E39+Aircond+Control+Unit-9144098.htm
shamkasio;624027 said:My latest bill for 523i @ 1996. Comments and advise are welcome:
Parts:
Valve cover gasket RM114.50
Bush RM112.50 (RM7.5 x 15pc)
Spark Plugs RM108.00 (RM18 x 6 pcs)
Ignition coil RM200
Front Wheel bearing RM320
Rear wheel ball joints RM300 (RM150 x 2pcs)
Ring RM40 (RM20 x 2pcs)
Front brakes caliper
repair kits RM56.00
Brake fluid RM29.00
Labor charge RM220.00
shamkasio;624027 said:Rear wheel ball joints RM300 (RM150 x 2pcs)
bimmerholic;624065 said:What brand are the ball joints? Lemforder?
bazet;625037 said:Original Fan Belt & Air Con Belt @ Heritage BMW PJ = RM528
bmw7833;625074 said:I changed both belts less than RM100, Continental brand.
Ori belts sure berry expensive.
