Herbert
Well-Known Member
- Sep 8, 2009
- 4,443
- 83
RaviKumar_E39;502096 said:do every 39 have do this and how often.pls advise.
Do WHAT smoking cigars !!!! :stupid::stupid:
herbert;502102 said:Do WHAT smoking cigars !!!! :stupid::stupid:
Jerman;502244 said:Herbert,
If I'm not mistaken, I believe RaviKumar meant the oil sump leaking? Yes, most E39s will experience the leaking and also around the power steering hoses.
"If it doesn't leak, it's not a BMW "
alantiong;508122 said:HUH?? reset ECU!! now that is a straight BS! the ECU is a ROM. unless he is remapping.. he cannot reset. What he mean is probably resetting the service light & logs, which doesnt make any differnt to performance.
The service list actually looks OK.
affan66;508343 said:got oil sump leak as well before the kuantan trip. Glad I discovered it and got it fixed... changed the alternator belt too... need to find my receipts.
bimmerholic;508513 said:Did your entire lower suspension was removed to gain access to the sump? What's the damage like bro?
affan66;508630 said:crossmember only. I also replaced the gearbox mounting which meant bringing down the exhaust, exhaust heat shield. I believe labor was RM280. half day job.
affan66;508725 said:for both... because i also changed the engine oil sump. need to get the exhaust and engine to cool down.
affan66;508756 said:removing the bottom cover alone is already more than 5 minutes. You gotta be kidding me. Your workshop got F1 pit crew ka? Or your car does not have the bottom cover?
Cooling down the engine oil and exhaust takes time. I took the opp to also check the longshaft bearings and all. Easier to inspect when all the exhaust, its heat shield is down. Inspecting belts and leaks is also easier.
affan66;508768 said:bro, what's with the icon? trying to prove something is it?
affan66;508756 said:I took the opp to also check the longshaft bearings and all.
