bono2k;457615 said:Hi bros,
Anybody has any idea how much front & rear absorbers cost ? OEM and Ori ?
Tqvm...
Jerman;457086 said:Just to share with the rest of the E39 owners. Changed the engine mountings (RM 148 x 2 pcs) and gearbox mountings (RM 38 x 2pcs). Labour = RM 50. All OEM parts.
IsaacVky;457660 said:I think most of the people here change to aftermarket absorbers.
Bilstein, KW, Sachs, Koni?
Bilstein B8 Sprint about 2400~2600 for a set of 4 absorbers.
Sachs Performance (equivalent to B6 Sport) is about 1800~2000.
bono2k;457783 said:If using the Bilstein or Sachs, Will it effect the original suspension e.g more harsh or even better after sport suspension .
i found out got two type.. monotube and twintube.. which one better ?
tqvm...
Tqvm...
bro,bmw7833;457779 said:Do u know what is the part number for the rubber mounting?
Jerman;458009 said:bro,
I don't have the parts number. These rubbers no "need rocket science" lah! Relatively small $ ticket items. Just change them you will feel "all the difference" :top:
Tqvm...
Gerald 5;447439 said:Did the below in 2 different occassion this month, anyone knows the price for ori front brake disc and pad? Am i slaugther?
E39 530i
1st bill
Brake Pad ori- 560 for a pair
Brake disc ori- 580x2= 1160
labour-60
total 1780
2nd bill
Water pump-190
Power streeing tank-135
Power streeing hose-150
Power streeing hose- 155 ( not sure which is in which is out )
Coolant ori-55
Thermostat with housing-260
labour- 130
total-1075
Tell me, tell me.. should I stick or should I run???
chong_chin;458327 said:4HP should be 4 speed ZF g/box then use ZF Dexron III or BMW original, 5HP is 5 speen then use ZF 5 speed trans oil. No need me to mention where can get them.
JYazid;458337 said:Gerald 5,
If you don't mind to share with us which w/shop charge you as above.
Achenggood;459565 said:hi bros
aku baru reg club ni tp da pakai bm 2 thn.
Alternator problem..!!!
Mane nk cari yg second hand??
Jerman;458008 said:The original absorbers on CKD E39 are Sachs. If you want comfort, just go for Blistein (black) = RM 400+ per unit for Front and RM 350+ for Rear
If you negotiate hard enough, you could get all 4 for RM 1600+
Gerald 5;458350 said:Don't think is appropriate to mention the names here, but they are near my place in Dataran Prima. No mean to cause any negetive impact on their biz and I know some forummer here are also their loyal customer. In fact, I have check with them on the pricing after checking with some sifu here and they told me that the sizes are different. Will be more careful in the future by asking a quote 1st. Cheers!
zank;459631 said:It is almost impossible to find a perfect shop, there are time they give you the best prce, they are times also they will cut your meat a bit from time to time, giving you extreme cheap for certain items, and then over charge you on other items. I think the best is call to those few tops shop in KL (Auto Bavarian, Inner Power, First Division, Munich Auto just to name afew) to check on the price, you can quickly know what is the average price, then typically shop will like to make some profit on top of that, I think 10-20% is ok as long as they provide the insurance warranty for a few months. After all every business needs to make some profit to sustain. As long the margin is not unreasonable.
You can also buy direct and get them to install for you, but you better make sure you know what you are buying to avoid time/energy hassle, beside shop sometime dont provide you warranty. it is a pros and cons, but for the simple hardware with no brain, you can buy direct and install in any tom/harry shop around, but for something more complicated, I will rather they make some margin to cover the warranty.
So, do you home work before getting cut.. and regret... also make sure you get the quote before proceed!
