hi guys,
just want to share my latest bill:
valve cover gasket = RM95
Radiator Bottom Hose = RM120
Power Steering Hose (pump to tank) = RM110
O-Ring = RM6
Power Steering Fluid = RM 21
Battery Water (2 Liter) = RM4
Radiator Coolant = RM16
Labour = RM120
Total = RM491
keigoayam;431820 said:
hi guys,
O-Ring = RM6
Labour = RM120
Total = RM491
where did you service your car? I need to replace my power steering hose.
hi guys,
O-Ring = RM6
Labour = RM120
Total = RM491
Radiator Coolant = RM16.....that's cheap! Is it the original BMW coolant (1.5L)? The last time i bought this is RM30 for a bottle.
hi cwlee,
I buy the parts at IP and bring it to Zeurosense Bdr Tun Hussein Onn
hi bimmerholic,
Its not original coolant ..i just use petronas 2L and mix it with battery water..
keigoayam;431983 said:
hi cwlee,
hi bimmerholic,
Dont play play with the coolant, must use the BMW ori one bro.
hi bmw 7833,
thx for the advice bro..will take note after this..
so far i do regular check up on the coolant...about once in 4 months
bought my a/c filter (with activated carbon) for RM 140, izzit a fair price to pay?
I was told that 97 E39 ZF g/box uses Dextron 3 fluid instead, can someone verify?
skinhead;432899 said:
changed my broken cable rear rhs pawa window rm1200
and a/c cabin filter rm130/set
Wah bro u kena cut throat?? Last time I bought my rear power window for only RM220 without motor. Its taiwan made but even ori will not cost more than RM500. Even the A/C filter also quite expensive.:eek:
i changed the whole thing plus motor , ori parts wit bmw logo., not only the the lifter. here in kl the price is about that range for ori lifter+motor.i asked around few shops, bav oto, 1s div, inner pawa, all quote me the similar range price. if u can get the rear lifter set for rm220, i might want to buy a set later for spare.
i know its expensive for meyle cabin filter.
:stupid:
initialM, he is right, if + the motor then RM1200 is reasonable for ori stuff.
Use Dextron 3 ATF in 5HP18 E39 ,.....get ready RM8K to repair.
cwlee;434189 said:
i was told only post 99 cars uses Esso LT ATF
Who told you? The guys from the US based forums? transmission fluids used are to be based on the type of gearbox not on the year of manufacture.
ZF gearboxes all use ZF or esso LT fluids be it year 1996 or 2002.. The Jatco Japanese gearboxes ( japan spec cars up to sept 1998) I think they use normal ATF Dextron II. Which ones are u talking about?
mine is dec96 uk spec.....guess it is 5HP18 that uses ESSO LT, the clowns
here must be ill advising me. I've got my other optra 1.8 that uses ZF 4HP16
that uses GM's ATF which cost RM79 per litre.
bro,
ZF oil for BMW cost about RM 50 per litre
thanks guys for the info....now i know Esso LT is the ATF oil for my 5HP18 GB
Have u guys heard of Berlin workshop in segambut, any good?
This, u can ask pcchuah. I think he's been there or going there for his service. I think they been around for quite some time.
Salam and good day bro,
I am following the thread quite some time and your learned advise is highly sought for my E39 520i 2002 local specs car.
Recently the car feel jerking notably during 2nd and 3rd gear. Must be due to regular commuting LDP whereby my gearbox stuck on these gears. Is it the gearbox nearing to kaput or something else. Thank you for your time.
