Hi everyone,
Some update and further advice needed on this topic. Please read on what was replaced recently: http://www.bmwclubmalaysia.com/forums/showthread.php?47970-Workshop-in-Penang&p=807039&highlight=#post807039
Basically, I replaced the oil separator (CCV) and 4 connecting hoses to no avail. It still has jerks during take off from idle standstill. A fault code (Gear Monitoring) logged on GT1 was present and my regular mechanic suggested a gearbox rebuild. Something to do with the torque converter ball valve.
What I need advice from you folks is what could cause a vibration pattern (not a harsh one but prominent and abnormal) at idle only when warm with constant RPM reading of 740-760rpm? Engine and transmission mounting were replaced a few months ago as well as fuel filter, spark plugs and all ignition coils.
Before and after the oil separator and 4 hoses replacement, the car has developed this pattern of vibration pattern. Something that is on and off, on and off kind of vibration that can be felt from the dashboard, steering, basically the whole car. Car is now scanned without any fault codes. The vibration is only present when car is operating at operating temperature.
Also the feeling of loss throttle, and I can recall this happened to me countless times is when you are at a busy junction waiting for a chance to cross, you found one and hit the throttle down to go fast. All of a sudden RPM went down slightly and no throttle for a brief moment of 1 second, then all of a sudden power came back. Scare the hell out of me
Throttle body was clean, Idle Control Valve (ICV) was clean as well. Both made no improvements.
Any advice, pointers are greatly appreciated. Thank you.
