e34 Parts and Maintenance Cost
feisaldzul
A/C belt - $20ABS Sensor RHF RM 380absorber dampers = 35(front), 30 (back)Absorber front RM290/rear RM280Air cond. filter RM184Air filter - RM48.00 (my filter got dirty after i took my car into Ladang Sepang during the Malaysian Rally!)Air Filter = RM33Air Filter RM 33 - RM 45 - RM 75Air Filter RM 35Air filter RM75 (dunno why costs more than M20 air filter)Air-Cond belt M20 RM 20Air-cond compressor RM 1600Air-cond gas RM 30Alternator (Bosch@115A) = RM1350 (the original was already 14yrs old).Alternator(potong kereta) RM 400Anti-roll bar tie rod (Ori) RM 100Auto gasket RM 50-60Auto gasket RM50Auto gasket RM60Battery ( Maintenance Free ) - RM275Battery ( Maintenance Free ) RM 200-275Battery ( MF GP) RM152Blower fan - RM140 (2nd hand)Blower fan (2nd hand) RM 140BMW Coolant - $22BMW Roundel - RM 30 ( hakitrade )BMW Roundel RM 30 Body Moulding Clip RM 3Boot Compressed Spring (1pc) RM 57 By-pass hose RM205By-pass hose RM205Camshaft sensor = 320Camshaft Sensor RM 320Castrol RS 10W-60 RM120 per 4-litre x 2 (bought from PJ)Center black grill (about 1.5 foot wide) - it's on the inside, excluding the chrome kidney frames RM83Center black grill (Internal) RM 83conrod bearings = 100Conrod Bearings RM 100Coolant level sensor : RM76 part, RM10 labourCoolant RM 22 - RM 25Coolant RM25Cooling Coil RM 1100cylinder head screws = 170Cylinder Head Screws RM 170Door Seals (Inner stuck to chasis, per piece) RM 258Drive shaft cv joint boot - RM 40/pieceDrive Shaft cv joint boot RM 40/pieceengine bearings = 80Engine Bearings RM 80Engine Oil (Full Syn 4L ) RM 110 - 130 Engine Oil Thermostat RM 67Expansion valve = 140(original), 110 (mercedes)Expansion valve RM 135-140expension valve - RM135Fan belt - $20Fan belt M20 RM 20fan clutch = 300 (behr)Fan Clutch RM 300fan cover = 110Fan Cover RM 100Front Absorber Damper RM 30-35 Front Absorber RM 290-320 per pieceFront absorber top mount - RM430 (gila punya harga )Front Absorber top mount RM 430 (gila punya harga )Front bonnet Heat Insulator RM 290Front Brake Disk (1 set) RM 420 Front Brake pad - RM 130Front Brake Pads RM 130Front Wheel Bearing RM 290-320front/back brake pads = 125 / 110 (Jurid)fuel filter = 80Fuel filter RM80-95Fuel filter RM95Fully synthetic oil RM110 for 4 litreFuses RM 2-3 gas - RM30Gasket RM28Gasket RM28 (dunno which gasket)GM solenoid valve (in A/T) RM 120Halfmoon seal (below the gasket) = RM5/ea. (you'll need 4)Halfmoon seal (below the gasket) RM5/ea. (you'll need 4)head gasket (thicker than normal) = 220 (victor reinz)Head Gasket (Victor Reinz) RM 220Headlights (Inner Lens) RM 225Heater hose RM97Heater hose RM97Hi-rev 9000 (6 Litres) RM 218 hydraulic lifters = 60/pieceHydraulic Lifters RM 60 per pieceIdling Valve RM 390Intermediate Light Bulb (Bluish White) RM 30Intermediate Light Bulb RM 6Jurid front brake pads (Bava Auto) - RM115 K & N Air Filter RM 230K&N air filter =230Labour RM335LH rear wheel bearing - RM95low beam head cover/lense = 120 (hella)Low beam headlight cover RM 120 per unitLow beam headlights L - RM158.80Low beam headlights R - RM158.80Low beam headlights RM 158.80 per unitlower arm (CTE Brand = 180, Lemforder = 230)Lower Arm RM 180-250 LowerArm (like bimmer520/5i's Alu type) = RM250Main Light Bulb H1 RM 22Manual Gear Shift Knob RM 70MF battery = 200 (century brand)MF GP battery -RM152 at eunoss, one utamaMiscellaneous (clips, washers, etc) RM68Mobil 1 (Full Syn 4L ) - RM130 Mobil One Engine Oil 8 litre 290.00MotoMeter SpeedoMeter Gearing - RM160MotoMeter SpeedoMeter Gearing RM 160Muffler ring - RM20 per pc x 2Muffler Ring RM 20 per pieceOil filter - RM28.90Oil Filter (Orig) - $35Oil Filter (Orig) RM 15 - RM 37oil filter = 15Oil Filter 35.00Oil filter RM 40Oil filter RM37Oil pressure switch = RM30Oil pressure switch RM30Oil strainer RM122Oil strainer RM122o-ring - RM30O-ring RM 30oxygen sensor = 650 (siemens), 550 (beru)Oxygen Sensor RM 550 - 650piston rings = 300Piston Rings RM 300plug Cable m20 - RM300Plug Cable M20 RM 300Power steering belt RM 16Power Steering Hose = RM165Power Steering Hose RM 165Power Steering Pump - 2 types RM700/RM1100Power Steering Pump (Type1) RM 700-1100Pro-Shaft Coupling RM 105 Pwr steering belt - $16Q8 Formula 1 10W-50 full synthetic - RM32.50 per litre x 7Radiator Coolant Level Sensor RM 76Radiator RM 700-1100 Radiator RM1100Radiator RM700 osso can be bought (BEHR)Radiator sensor RM 270Rear Absorber Damper RM 30-40 Rear Absorber Lower Spring Pad RM 30 Rear Absorber Mounting RM 90 Rear Absorber RM 280-300 per pieceRear bonnet rubber RM 120Rear Brake Disk (1 set) RM 300-330 Rear Brake Pads (4 pcs) RM 160Rear bushings (on support arm) : RM294 part (1 pair), RM30 labourRear Bushings (on support arm) RM 294 / pairRear disc pads (four pcs) RM160Rear wheel bearing - RM90Rear Wheel Bearing RM 90-95 receiver-drier/filter - RM170receiver-drier/filter RM 170Redline D4 Synthetic ATF (1 Quart) RM50Redline D4 Synthetic ATF RM50 x 4 quarts (bought from Autobags)Reverse Light Bulb RM 6Rubber Boot 25.00Rubber Mats (1 set) RM 75Silencer box (from the 2-page-ad-shop in motortrader) = RM320Silencer box RM320Spark Plug 108.00Thermostat = 45Thermostat RM 45Thermostat RM67 (for engine oil temp)thrust arm - 260Thrust arm - RM200/pieceThrust arm bushing - RM 65/pieceThrust arm bushing - RM60Thrust Arm bushing RM 60-65 /pieceThrustArm bushing = RM65Timing bearing - $55Timing Bearing M20 - RM50Timing Bearing M20 RM 50-55Timing belt (Orig) - $ 175Timing Belt M20 - RM 50 (cheapo) RM 150 (quality)Timing Belt M20 (cheapo) RM 50Timing Belt M20 RM 150-175timing chain = 110Timing Chain M50 RM 110timing sensor = 300Timing Sensor RM 300Track rod (aluminium) RM 270Track rod RM 270 (aluminium)Upper / Thrust Arm RM 195-210 / unitUpperArm (ThrustArm) = RM210used front foglights +3pos switch+4leg relay+fuses = rm300valve cover gasket = 80Valve cover gasket = RM25 Valve cover gasket RM 25Water hose (fr thermostate housing) - $40Water hose (fr thermostate housing) RM 40Water hose (fr water pump) - $80Water hose (fr water pump) RM 80Water Pump - RM120Water Pump - RM120Wiper Blade 90.00Wiper Rubber RM 40-45 ZF 5hp-18 repair kit = 850ZF 5hp-18 repair kit RM 850
kenapa? tak percaya ka? ( ala BCB ad)hahahaha ayoyo dude if i did all that on my car, die oredi la
1) need to change the front brake discs on my e34...checked the list and it said rm420 per set
anybody have any idea if the price is for a pair or just one piece?
2) my water pump needs to be replaced as well...as always there is a german replacement part and bmw original part...i think the german OE is rm220 and the bmw original part between rm360-rm400
anybody knows if there is much difference between the two parts?
aik i tot u were the one who put the list down ? now u askin hahaha
no idea bro..
__________________
Tsuiso.. :ph34r:
aiya taukeh...that list i saved from the previous site la...others posted it...not mine...hehehe...dont shoot me la :p
I paid around RM480 per piece for the ori BMW brake pads. Heard that the "compatibles" are around 400+ a pair, but the braking system is one of the few things I'd rather not stinge on...
:rolleyes: :rolleyes: :rolleyes: :rolleyes:
My water pump need to change also la.
Went to investigate the price to E.Y.L Service in Desa Pandan
RM 240 + labour RM 60. Then ask my regular mech for my proton
car and he said around RM 160 excluding labour.
I have no idea if both are german OEM or BMW ori.
feisal> is your water pump leaking ka? According to the EYL mech,
mine is leaking and that caused my radiator minum banyak air.
2 times a week minum air at 1.5L per refill.
hi amizana,
>My water pump need to change also la... mine is leaking and that caused my radiator minum banyak air. 2 times a week minum air at 1.5L per refill
wah, that's plenty of refill man! suggest you replace water pump (and thermostat) the soonest. mana tau one day too sibuk no time or forget to put water then kena stuck in bad traffic jam... engine overheats... if that happens, sakit man...
Probably for 2, I think I put that up quite a long time ago, can't remember exactly, if I dig up the invoice I will update you. However, a faster way would just to give BA a call and check. Price might be higher now due to Euro.
Resurrected from the dead, I found this in my computer. The complete list from the old site:
Summarised with what I have with what you guys posted on this tread and the old e34 maintaince thread.
Note this is just a price guide, prices varies with brand I am sure and also time of purchase. Feel free to add to list.
This list will be edited from time to time with new items.
Air-Conditioning
M20 Air-Cond belt RM 20
M20 Fan belt RM 20
Thermostat RM 45
Air cond. filter RM 184
O-ring RM 30
Air-cond gas RM 30
Brakes
Rear Brake Pads (4 pcs) RM 160-178
Rear Brake Disk (1 set) RM 300-360
R/H/F ABS Sensor RM 380
Cooling System
Fan Clutch RM 300
Fan Cover RM 100
Heater hose RM97
Water Pump - RM120
Drivetrain
M20 Timing Belt(cheapo) RM 50
M20 Timing Belt RM 150-175
M20 Timing Bearing RM 50-55
M20 Plug Cable RM 300
M50 Timing Chain RM 110
Piston Rings RM 300
Tensioner bearing RM 50
Adjuster bearing RM 75
Idling Valve RM 390
Gasket RM28
Valve cover gasket RM 25 - 75
Rocker cover gasket RM 75
By-pass hose RM205
Drive Shaft cv joint boot (per piece) RM 40
Output shaft oil seal RM 55
Gear box mounting (2 pieces) RM 70
Electrics
Alternator (Bosch@115A) RM1350
Alternator belt RM 54
Exhaust
Silencer box RM320
Power Steering
Power Steering High Pressure Hose RM 800
Steering side/tie rod RM 140
Suspension
Rear Absorber Mounting RM 90-145
Windscreen
Windscreen Front RM 650
Miscelaneous
BMW Roundel RM 30
Consumables
Oil Filter (Orig) RM 15 - RM 40
Oil strainer RM122
Air Filter RM 33 - RM 47 - RM 75
Fuel filter RM 39-80-95
Fuses RM 2-3
Spark Plugs (6 units) RM 54
Services
Skim disc - front (a side) RM 35
Hi
Happy New Year to all Chinese friends!
Did some minor repairs at BM World last week:
Control Unit (Used - under backseat that controls power windows, central locking, wiper etc.): RM200
Starter solenoid switch (sorry lupa tanya brand): RM80.00
Labour: RM70
Rgds
Faiz
hai guys iam new here...so where is this bm world.need some help cause need to sent my mom car for a timing belt change.is a e34 520i 1989
U HAVE A VERY LONG LIST OF SPAREPARTS.ALL THE THE PRICE FOR SECONDHAND OR NEW?IF SECONDHAND, WHICH WORKSHOP DID U TAKE UR CAR?
I NEED TO CHANGE MY 520i (94 MODEL)REAR UPPER ARM AND LOWER ARM.ANY SIFU'S OUT THERE WHO CAN HELP ME WHERE TO FIND SECOND HAND SPARE PART?
IMHO wear and tear parts such as upper and lower arm you should get new instead of 2nd hand. You do not know the condition of 2nd hand parts and how long they will last esp for high wear and tear parts like the suspension components. Who knows you get a 2nd hand set, they work great then 1 month later they go KO on you and you need to folk out $$ again to buy parts and labour to install.
Might as well buy new parts which you will know will last you at least several years. Other none essential parts such as lights, handles, steerings, body kits, etc are a good bargain 2nd hand and you do not need to worry abt them breaking down since they are mostly passive components.
If you are really on a budget then I guess no choice lor, go for 2nd hand suspension parts. Thats just my 2 cents worth.
just purchased ATE brake pads for my E34
Front RM135/-
Rear RM110/-
FLY
