andrewlim8
- Feb 13, 2008
- 162
242k for 320i and 248k for 320d, which one will you choose??
mizhan;762019 said:320d. 380Nm, RM10/100kms.
andrewlim8;762021 said:ok !
will 320i engine is more tunable as compare to 320d, since 320i is using the 328i enigine??
_M_;762060 said:The same N47D20 engine in 320d is also being used in F10 525d, tuned up to 215bhp and 450Nm.
So both are tunable quite abit. Tech wise, the diesel engine is older having been around since 2007 whereas the petrol was only introduced last year.
c-square;762074 said:Since it is the same engine (the 320D and 525D) how does one get the stock engine on a 320D to be"tuned" to match that of the 525D?
docrayboy;762100 said:chip the 320d.......create a monster in 2 minutes. Plug n play chips....vector, dtuk, racechip......
c-square;762101 said:How much does these little bad boys cost?
astroboy;762105 said:The force inducted 320i also can be chipped because of having turbo ma. The "d" will have much better torque and more than double the fuel efficiency. Trade off being the possible reliability issue due the highly contaminated diesel.
From marketing perspective, there's no diesel variant in that segment among the competitors, so BMW may want to retain the higher margin while letting the petrol model compete even with lower spec just to make the price competitive.
docrayboy;762106 said:still its hit n miss with the turbopetrol chips with no major improvements in hp/torque....friends who own the turbopetrol Golf GTI have often said this.
docrayboy;762104 said:from 500 ringgit to 1800 ringgit...cheap for the added torque n hp u get....plug n play....malaysia has a vector vendor forum nickname tazzhyam aka Derek 012 211 8381. call him. try the Vector today! Change your F30 320d or F10 520d into a BEAST!
astroboy;762108 said:There's a limit in chipping until a stage where you need extra cooling and bigger snail turbine, and down pipe. You must understand the GTI is already stock 200hp... and there're many 300hp GTI lurking around... dun play play..
What's your diesel output after chipped?
docrayboy;762113 said:Wuk51 dynoed his vectored 320d...now he gets 197hp and 447Nm torque from 184hp and 380Nm torque originally
andrewlim8;762148 said:anyone know a vectored 320d can do 0-100 in ?? sec ?
can Wuk51's 320d beats a stock F30 328i ?
jason;762152 said:This is discussed here http://www.bmwclubmalaysia.com/forums/showthread.php?46870-328i-vs-320d-F30.-Dilemma...&p=760987&viewfull=1#post760987
I would say it will come darn close but still kennot beat the stock 328i.
Jason
andrewlim8;762155 said:bro,
7.3s v 6.1s is not close la.....
even as compared C200 8.5s with Passat CC 7.8s, i could feel CC is a lot quicker
AstroKid;762407 said:My friend forwarded me a photo he claimed to have taken outside AB. Can anyone verify by looking at the brake lights if it's an F30 ? Thanks View attachment 25836
