Today my UV-5R arrived. Time for the first impressions, and a few measurements. For a start, comparing the new UV-5R with the UV-3R seems pointless. The full-featured UV-5R is a totally different ball game, and comparing this handheld with a Wouxun or a Quansheng would make much more sense.
In the box
The transceiver itself, one 1800mAH Li-Ion battery, a sturdy belt clip, a desktop charger with separate power supply, a dual band antenna, a headset, a small wrist strap and a manual.
First impressions
- Very nicely built, looks quite sturdy, especially when compared to the rather flimsy UV-3R
- Excellent dual frequency display with three background colors (Amber, Blue and Purple)
- Quality antenna
- Good ergonomics overall (but it’s very easy to hit the FM radio key instead of the ptt key)
- Decent desktop charger
- A not-too-bad FM radio
First steps
The manual states that the battery is not pre-charged and needs to be charged for about five hours. The lamp went green here after spending just two hours in the charger. The first thing I had to do was diving into the menu to set the channel spacing to 12.5KHz on VHF, and 6.25KHz on UHF. Piece of cake. Then I programmed the repeater shifts used in the Netherlands: 600KHz on VHF, and 1.6MHz on UHF. No problems at all.
The first UV-5R bug
I rarely program frequencies into memories. The reason is that I only use just a few local frequencies, which are just as easily accessed from a keypad. That doesn’t work well in the UV-5R. In spite of the fact that I set 12.5KHz channel spacing as default, it proved impossible to enter a frequency like 144.5125. On any other handheld, entering ’144.512′ is enough, and the missing ’5′ will be added automatically. The Baofeng on the other hand sets the frequency to 144.500, after which I have to use the ‘up’ button to increase the frequency by 12.5KHz. The same problem occurs on UHF. Silly.
Memory programming
Programming a frequency into one of the memories is no easy task, especially because the correct procedure isn’t described in the manual. I quickly found out that I had to erase the existing memories first by accessing menu 28. Secondly, only frequencies visible in VFO A can be programmed. Normally you can program a repeater by setting all the necessary parameters and writing it into the memory only once. With the UV-5R, you have to program it twice into the same memory: the receive frequency has to be stored first, the second time the transmit frequency will be stored.
This might seem odd (and it is, in a way), but this system does allow you to make odd splits. When you have the voice prompt switched on, you can actually hear a female say whether you store a transmit or a receive frequency when accessing menu 27.
Audio (TX,RX)
Both fine. There’s no volume problem to report, nor a muffled TX audio. No distortion to report either; the speaker does a good job.
Sensitivity, selectivity
Sensitivity appears to be on par with any other quality handheld. Contrary to the UV-3R, the new UV-5R is perfectly capable of handling strong out-of-band signals. That is a relief; bad front ends and RX filters would be a real deal breaker for me.
First measurements
I checked a few things today: power output, frequency accuracy and stability. Only calibrated test equipment was used.
Power output VHF:
136.000 MHz: High=3.4 Watts, Low=1.6 Watts
155.000 MHz: High=4.0 Watts, Low=1,75 Watts
175.000 MHz: High=3.8 Watts, Low=1,8 Watts
Power output UHF
400.000 MHz: High=3.0 Watts, Low=1,75 Watts
440.000 MHz: High=3.1 Watts, Low=1.1 Watts
480.000 MHz: High=2.3 Watts, Low=1.0 Watts
Frequency accuracy and stability (room temperature)
Display frequency 145.000 MHz, Counter frequency = 145.0000 MHz
Display frequency 440.000 MHz, Counter frequency = 440.0000 MHz
Stability: +/- 0.00001 MHz (which could as well be a minuscule rounding error of my frequency counter)
best antenna upgrade
Nagoya NA-701
Preview: Baofeng*UV-5R
The new Baofeng-UV-5R
The first thing I thought when I saw this new version, was “Hey, I know that thing”. And indeed, the casing of this new handheld is identical to the TYT TF-F8. The difference: the TYT versions are single band, the UV-5R is dual band. Yet the price doesn’t reflect this; the UV-5R is about as expensive as a single band TYT. The current price hovers around the $55 mark.
Differences
When compared to the now (in)famous UV-3R and its varieties, there are some big differences to report. Power output is one of them – 5 Watts on VHF, about 4 Watts on UHF. The battery pack is rated 1800 mAH, and a decent desktop charger is part of the package. The UV-5R also supports DTMF. All of this promises the UV-5R to become the cheapest full-featured dual band ever.
Some questions remain, and answers will have to wait until I have finished testing mine. Harmonic suppression is one of them, and I’m also curious whether the receiver will be able to cope with the insane amounts of out-of-band signals I’m dealing with here. We’ll keep you posted, and a proper review will follow as soon as possible.
Technical specifications
Frequency Range: 136-174 / 400-480 MHz
Frequency Stability ±2.5ppm
Dual-Band Display, Dual Frequency Display, Dual-Standby
Output Power: 4-5 Watts (VHF), 4 Watts (UHF)or 1 Watt, selectable
Modulation Mode 16kΦF3E / 11kΦF3E
Maximum deviation <5kHz(Wide) / <2.5kHz(Narrow)
Spurious Radiation <7μW
Adjacent Ch. power* ≤-65dB(Wide) / ≤-60dB(Narrow)
Pre-emphasis characteristics 6dB
Current ≤1.6A(5W)
CTCSS/DCS deviation 0.5±0.1kHz(Wide) / 0.3±0.1kHz(Narrow)
Memory capacity: 128 channels
50 CTCSS and 104 CDCSS (includes tone searching)
Built-in VOX Function
1750Hz Burst Tone
FM Radio (65.0 MHz – 108.0 MHz, WFM)
LED Flashlight
Large LCD Display
25KHz/12.5KHz Switchable
Emergency Alert
Low Battery Alert
Battery Saver
Time-out Timer
Keypad Lock
Monitor Channel
Channel Step: 2.5/5/6.25/10/12.5/25KHz
Roger beep
Emergency Alarm
Tri-color background, selectable
PTT & ANI ID
FM radio and 25 stations storage
PC programmable
Transmitter time-out timer(TOT)
Busy channel lock-out(BCLO)
Current ≤1.6A(5W)
Intermediation sensitivity 8-12mv
Intermediation distortion <10%
Dimensions:(W x H x D)100 x 52 x 32 mm
Weight 250g (including battery, antenna)
About these ads
Like
Be the first to like this.
March 20, 2012 - Posted by Hans | Amateur Radio, General, HAM Gear, HAM Radio
Baofeng UV-5R bugs to*date
Direct frequency access. See Baofeng UV-5R Review Part 1.
There are 9 settings for the squelch threshold, but changing it doesn’t make a difference. Whatever the setting, the Baofeng wakes up at -129dBm on VHF, and -126dBm on UHF. Under normal conditions the default squelch threshold seems to be just right, but in a noisy environment this bug might haunt you.
The same is true for the VOX sensitivity. It doesn’t matter what setting you choose, the sensitivity stays the same.
Kuala Lumpur Radio Stations
LOCAL
102.5 | RTM Asyik FM - Lain Dari Yang Lain
Lain Dari Yang Lain
Local Music | Kuala Lumpur, Malaysia
89.3 | RTM Ai FM
Love FM commuting family
Adult Contemporary, Top 40-Pop | 吉隆坡, Malaysia
104.9 | Red FM - Today's Best Music
Today's Best Music
Adult Contemporary | Kuala Lumpur, Malaysia
93.9 | Radio 24 - Real Life Real Time
Real Life Real Time
News, World Talk | Kuala Lumpur, Malaysia
90.7 | Putra FM - Suara Kampus Tekini
Suara Kampus Tekini
College | Serdang, Malaysia
88.1 | One FM
莫文蔚 - Wai Mian De Shi Jie
Hot AC, Asian | Petaling Jaya, Malaysia
101.8 | MY FM (My FM) - My FM My Music
My FM My Music
Top 40-Pop, Chinese | Kuala Lumpur, Kuala Lumpur, Malaysia
94.5 | Mix FM - Malaysia's Best Variety
Adult Contemporary | Klang Valley, Malaysia
105.7 | Lite FM - Famous For The '80s
Famous For The '80s
80's, Smooth Jazz | Kuala Lumpur, Malaysia
98.3 | Klasik Nasional FM - Segalanya Di Sini Menggamit Memori
Classical | Kuala Lumpur, Kuching, Malaysia
97.2 | KL FM - Rentak Interaktif Kota
91.5 | IKIM FM
Fi Rihabi Ramadan
Ethnic | Kuala Lumpur, Malaysia
97.6 | Hot FM - Lebih Hangat Daripada Biasa
Adult Contemporary, Top 40-Pop | Kuala Lumpur, Malaysia
92.9 | Hitz FM (hitz.fm) - Playing You All The Hitz
Adult Contemporary, Top 40-Pop | Klang, Malaysia
95.8 | Fly FM - Hot New Music
Hot New Music
Top 40-Pop, Adult Contemporary | Putrajaya, Malaysia
103.3 | Era FM - Rentak Muzik Terkini
88.9 | Capital FM - Pulse Of The City
Pulse Of The City
Asian, Variety, Women | Kuala Lumpur, Malaysia
89.9 | BFM 89.9 - The Business Station
Business | Petaling Jaya, Malaysia
104.1 | Best 104 FM - Sensasi Selatan
Sensasi Selatan
Asian | Kuala Lumpur, Malaysia
STATIONS
98.8 | 988最好听 (988FM) - 24 Hours Of Pure Chinese Infotainment
Ha Music
Top 40-Pop, Adult Contemporary | Kuala Lumpur
