rafamr;621059 said:how do we know the adjusters broken? even my newly installed headlights also give me headache when i want to adjust... any special tools needed?
seewai;621049 said:No lah bro, as mentioned before somewhere in some thread, that H/lamp set was already 8 years old and very poor condition with stone chips and yellowish cover. Give to you for free also you'd :vroam::4:
tweiboon;621067 said:If you give me sure i want. Yellowish never mind can make it clear again and i can open the lamp and take inside spare part also mah
seewai;621069 said:Ok bro, the next time I visit the workshop I tanya bos tu see whether they're still there or not. If yes, I will claim them back and let you have it.
seewai;621062 said:For my case, when trying to adjust the h/lamps hi-low using the lever 0 - 1 - 2, can hear some clicking mechanical movement sound but light not going up nor down, just 'shiver' slightly.
If your new h/lamp assembly is the ori set, I believe as long as it's properly installed, should work without needing special tools.
bmw7833;621075 said:Actually there is a machine in AB to align the proper light pattern. They charge RM50 per side. If u are a DIY kaki, then u can do it yourself. Just google the info and do it step by step.
Look at the headlight, u probably can tell the adjuster still ok or not. Else check whether there have small white piece inside the housing, if yes, then adjuster broke ady.
tweiboon;621079 said:For want to 100% sure is turn the adjustment nuts. If after turn the nuts also not seeing the headlight moving then 100% sure your adjusters broken already.
bmw7833;621080 said:In my case, no. My light still can move even my adjuster ady broke when i adjusted the dial, but only little movement. Because there are 2 adjusters per side, so even only one adjuster is ok, the light still can move up and down a bit.
mick123;622985 said:finally tak boleh tahan with my faded, pitted, yellowish headlamps with broken adjusters. so went scouting around sunway for a pair of new glassesfound 2 shops that carry made in taiwan headlamps that come with motor, whatever that is
according to the shop this motor is the same as the adjusters. not too sure about that. the shops offered rm2.3k for both front and back lights. worth it?
bmw7833;623010 said:I would say "NO" to the Taiwan made headlight. The eye more likely a frog eye than angel eye.
Alex5522;623126 said:
tweiboon;623252 said:RM 2200 for new original angel eyes, then half cut with broken adjusters headlights need to pay RM1200. For what want to buy half cut ? The half cut seller really got problem.
