astroboy
Well-Known Member
- Dec 15, 2006
- 8,734
- 63
ALBundy;487090 said:Even though, the cars are pretty similar (assuming same wheel diameter, no bodykit and etc) the results could be varied.
Recently BMW Msia did a drive using the 320D, with the target of achieving 1000km utilising only a single tank. Not every participant achieved the target.
The biggest variable when it comes to fuel consumption is the right foot. Even if one were to convoy, the driving style do make a difference as well.
For example, I like to accelerate when driving on a downhill descent and use the momentum generated to climb the subsequent hill. This is more efficient than to accelerate up the hill, and then cruised downhill.
You can try this tip when on the Maju Expressway to Putrajaya![]()
So were u in the test?
Yah! I love to tail gate fast coaches, FC improve tremendously! For that matter, all cars that tail gate others will benefit from the slip stream to achieve amazing FC!! Aircond temperature don't set too cold is also one of the trick. Tyre pressure put a little harder.. and many more! Rule of thumb is DON'T BRAKE TOO HARD! and DON'T ACCELERATE TOO FAST!
