ALBundy
Founding Member
- Dec 4, 2004
- 11,610
- 38
Schwepps;486457 said:Shell ULG95 and ULG97 would have the same sulphur content (whatever that is) as they're the same base gasoline coming through the same pipeline from Shell PD. In fact, on occasions when there is shortfall in Shell production, you might even be pumping Petronas base gasoline from Petronas Melaka. That's how it works folks.
Attached in this link is something interesting for all to note, despite all fuels originating from the same source/refinery (interesting to note that Shell and Esso/Mobil fuel comes from a different refinery as indicated in the link below).
Go to page 12 of the research paper, there is a table indicating the RON levels from various brands. Lowest is RON 96.4 to a high of 97.7!! The sulphur content levels are marginally different as well.
http://images.paultan.org/uploads/2007/02/2-3a.pdf
I have googled further on methods used to measure RON level, and it is interesting to note depending on which method is employed there is a margin of error of +/- 0.5!!
Most accurate is to use a fully automated device.
http://www.freepatentsonline.com/5606130.html
