infinityKL
- Feb 10, 2007
- 3,562
go pump the V first thing in the morning...!! vroom vroom...
shanthan60;443466 said:is it ok to use different bands of fuel in my E90323i,am using esso synergy F-1,which i think is ron97 but am planing to change to vpower,will this damage my engine?
Schwepps;443534 said:No worries whatsoever. You can mix any brand and RON 95, 97 and V-Power with no ill-effects. It's likely that all the brands come from the same base stock anyway. Just don't fill Ron 92 (if you can find it) - it's below the recommended minimum for E90s.
Traveler;443580 said:My manual (325i) states the absolute minimum as RON91, while stating that our nominal performance figures are based on RON98 fuel.
etquah;443595 said:Mixed half tank each type last week, can't feel any difference anyway.
racheltoh;443670 said:because you are not racun yet by the gang..
btw, how do u mix half n half? or is it done at 2 different timing?
Schwepps;447319 said:No la, I just filled up with V-Power at Eastin Shell. Contest forms sudah habis!
glock_8;447382 said:i just fill up the first form and staple the rest together with empty form...will that count?
