kby88
- Jan 3, 2008
- 291
Ya, i've told the mech to change the vacuum pump seal.
And on top of it, i'll replace all the valve seal too since already take off the valvetronic motor+camshaft.
Iceduke;767376 said:For Spark plug 1 & 4 can DIY, but afraid that 2 & 3 is tricky as you need to remove the valvetronic motor unit and possibly the camshafts as well...
while you are at it, might as well change the vacuum pump seals and the back plate for the engine coolant.![]()
