To M-Sport my E39 and some questions
bazet
Hi guys,Mine is 2003 520i 2.2 comes with M tech bodykits now I'm seeking advice to :1) blackened door sills. On my previous E34, , I used Tamiya spray but the color easily peeling away. So any idea how to blackened the sills ? 2) Where is Selvam new place ? Last time I went there, there was E60 M Sport sport rim lying....now I'm going to replace my wheel to either a) M Parallel 18" staggeredb) E60 M Sport 18" staggered3) I just moved out to Kota Warisan, Sepang. Any reputable BMW mechanics around here ?Thank you.Azril
bazet....use hi temp paint.4 times more expensive than normal spray can paint but will last very much longer.
around here.....nilai/bbst no real specialist la....but for general service you can try the one in kosmopleks bbst.....ah kheong w/shop....they even have the service reset tool and engine diagnostic computer.....
ok abang moot......u tinggal area mana ? Saya upah abang moot catkan boleh :D
I think I've seen people using black tape to blacken the door trims. It works and is quite durable. Need to use a heat gun to soften the tape a bit and mould it to get a clean line along the trim.
You'd need an M-sport steering to improve the interior:
bazet;580817 said:
Hi guys,
Thank you.
Azril
e60 rims and e39 rims tak boleh ngam. If you still insist, have to modify, but not advisable.
fro M-para - do u want ori stag, replica or German made ...
ori stag - Anakin
Replica - Dir
German stag - mine
All for E39 - meaning dun need center cone
ori stag - Anakin
Replica - Dir
German stag - mine
And your Mpars are unmistakably special ones :wink:
Plan to push to 19" - hence the intention to let go the M-para. :rock:
paultantk;580935 said:
i seriously discourage any boring of wheels to fit e60 wheels to e39
shaky
i agree with bro paul, my fren using m5 e60 rims on his e39 experiences shaky drive at 90kph to 110kph...he is so uncomfortable with it...the rims needs reboring before fitting to his e39..just for sharing...
