YellowMellow
- Mar 15, 2006
- 481
Ozone
How is your ride? everything is good?:top:
Regards
YM
Regards
YM
YellowMellow;296325 said:Ozone
Regards
YM
ozone;296400 said:Paddle shift did not work last week whilst driving to Ipoh.
Went to do a modic and fault registered was steering column. Could not even erase the fault.
Since the dealer gave me a 1 year warranty, he asked me to go to a specialist who pressed a few buttons on the steering wheel and suddenly it worked. According to him there are occassions where the wires sometimes touch thus causing the malfunction.
Modic also showed fault on the lights but was told that this is because HID lights was installed.
Other than that, my usual workshop told me that everything on the car is OK and I do not need to spend any money to change parts right now.
Getting used to the SMG now - learning how to balance it on a slope and can do it most times now.
Thanks.
Thanks.
ryan8687;296623 said:hi Ozone
can u tell me where did u go to repaire the paddle malfunction....coz i have problem with my shifter too...
The paddle can perform up shifting but the down shifting is not at function...
please help....anyone?
regards
ryan
YellowMellow;290008 said:Congrats for you new ride.:top:
Now is the SSG/SMG1 common problem.![]()
SMG gearbox computer box attached at the gearbox itself. (design failure by the stupid Italian gearbox designer, computer box for gearbox in an M3 SMG which is by siemens is located the engine bay and covered) If you stuck in the jam during hot weather for quite sometime, the computer box cannot give proper input to the gearbox. Meaning you car cannot move even to press the fuel.
The solution is to open the under carriage engine cover to give more air circulation at the gearbox area. Or put your ceiling fan near the computer box:stupid:
YM
Alan Teh;299149 said:u should go to the authorised dealer to have a check, they will let u know whts wrong with ur car. I think this must be clutch is slipping
ozone;299139 said:Yellow Mellow
Was stuck in a jam for an hour just now ( it is raining in KL ) and the gearbox went all funny - from standstill, I can still shift between 1st and 2nd but when I press the accelerator, the car does not respond until the rpm is about 2.5k then it started moving slowly. After a while, the car can barely move and it felt very jerky and when I press the accelerator, you can hear the gear changing very loudly but the car is hardly moving. I turned the engine off for 2 mins and it was normal again. Then after another 5 mins of driving, it happened again.
Finally got home.
Is this the symtom of what you describe as computer being too hot ?
If yes, then I will go and remove the cover as you mentioned.
If not, pengsan, got to go to Sapura on Monday am![]()
YellowMellow;299355 said:The problem just begin bro..
The cause of the problem:
1) computer box
2) gearbox hydraulic system.
The problem that you mentioned will come again if you stuck in heavy traffic.It's nothing to do with your clucth pad. Ask AB/Sapura to re-program your gearbox before change both items of above items.
The immediate solution that you can take is avoid heavy traffic road.and open the cover to give more air at the gearbox area.
Goodluck bro..
ozone;299418 said:I hope mu case is not scaring off anyone who is thinking of getting SMG ......
ozone;299417 said:Oh shit.
Why do I need to reprogram the gearbox - is there something wrong with the programme ?
Any idea how much to reprogram the gearbox, change the computer box, gearbox hydraulic system ?
Have you done yours or you just removed the cover only ?
Susah lah, how not to get caught in jam in KL ?
YellowMellow;300343 said:Do the re-programing first. (RM60 if I'm not wrong) At the same time please get the comment form the AB/Sapura. Please post their comment.:listen:
Make a complain to BMW Malaysia as well. They will monitor your car status.
To answer your questions bro Ozone:
I have changed my gearbox + clucth pad + ECU...AB gave me 50% goodwill warranty + 2 years warranty on all the parts. Noticed that my new gearbox + ECU version is different part number and version with our old gearbox + ECU version. AB said it's improvise version done by the Italian.....
.. My ride now is superb..:rock:
Goodluck mate..
YM
Btw I'm in Germany if you want to get clucth pad please let me know. I can get cheaper here.
ryan8687;301131 said:i went to Mspeed workshop just now...to get second opinion from ah meng in regards of my faulty paddle shifter...
he suggested to do software upgrade of the engine and the smg system. he quoted me rm 250 to do both..only then he can determine what is the cause of the malfunction downshifter.
he also mentioned the easiest way to identify the problem is to swap smg steering...if it's working surely ..so is not cause by the steering..
yellowmellow did mention regarding the gerbox upgrade...do u think i should go to AB Sapura instead of Mspeed ?
Ah meng mentioned better to upgrade engine software as well... follow by gearbox upgrade. is this necessary?
please help
regards
Ryan
please help
regards
Ryan
