Update...
Lower Arm Control PU Bushes -
Squeking sound finally disappear (although it can still be noticed when going over bumps but much better now) after trying for 3rd times - second time last only few days, later found out that the bracket which holds the lower arm bush was not properly sitted into its position, luckily this didn't spoil the bushes.
Rear Diff -
Last week only got chance to check the ratio on previous unit - 3.45. The used unit currently using is 4.45 :blink: !!! No wonder rpm so high even only doing 100km/h. Actually 4.45 Diff should be for what model ah?
Engine -
Sigh... not enough $$$ to change to M20B25 liao :cry: , got to remain using my existing L-Jet M20B20, but will need to do some repairs.
Here are the problems that haven't solved (& some newer problems):
1. Oil leak to Air Fliter.
2. Noisy Valve Guide.
3. Abnormal engine temperature, occasionally goes up nearly 3/4 and stay there for quite some time, even travelling 90 - 100km/h on highway (happen since last month).
4. Losing coolant every 6-7 days with no sign of water leakage (happen since last 3 weeks).
5. Abnormal idling speed, rpm shoot up to 1,500 - 1,800 during cold start, and stays above 1,000rpm at working temperature (happen since last month). Mechanic said it's due to Air Slide Valve failure. Any idea how much this thing cost (new)? Is there any member has used unit to let go?
Other problems:
6. Stiff gear change. Engaging 1st gear is almost impossible if the car was not use for few days. If use daily also occasional stuck in 3rd gear, will need to use little bit force to pull it down.
7. Power Steering sometimes not functioning, kadang-kala power assisted, kadang-kala heavy (Steering Rack had been repaired on April 05). Mechanic adviced to change Power Steering Pump, but I prefer repairing it. Still looking for someone who can do it.
8. Steering bush cracked, noticed it this morning!!
9. Power window (behind driver's side) malfunction, previously replaced a used motor but last only 2 months.
10. Seat cover worn out.
11. Cracked L+R Grille and Kidney Grille, thanx to knocking a steel bumper PROTONG SAGA
12. Faded Headlamp.
13. Body rust here & there, especially floor panel.
14. Faded Paintwork.
WANTED - $$$$$$ :cry: :cry: :cry:
